Tranny Fluid
/ Tranny Fluid #1
branman1971
Texas
Yanmar YM1700
I got around to changing my tranny fluid today and to check the screen that lives under the 3 bolt plate. I looked at the color of the new tranny fluid and realized that the old fluid is almost white in color, and it kinda has me spooked. I dont know if water got into it or if someone put the wrong kinda fluid in it or what. What do you guys think this is?
/ Tranny Fluid #2
Yes, looks like water got in it? is the shifter boot missing?
/ Tranny Fluid #3
I would say that there definitely is water in that oil. Do you have any idea how long its been since the oil was changed?
/ Tranny Fluid #4
Sure seems like water got in there. I had a similar problem when I bought my 186D. I had a bad (cracked) filler cap which allowed water to get in. Recommend you drain it all, clean screen, replace filter and fill with JD303. You can also use Dextron 3 ATF if you can't get the JD303. I've used the ATF with no problem....so have many others. Good luck.......:thumbsup:
/ Tranny Fluid
Replace what filter? This isnt motor oil by the way, this is tranny/hydraulic fluid tank.
/ Tranny Fluid
I dont think the previous owner did any maintenance on this old gal the whole 5 years he had it.
/ Tranny Fluid
The screen under the 3-bolt panel on the bottom is destroyed. Is it bad to run the tractor without the screen until a new one arrives? I would like to fill it back up with fluid for the time being. I guess I will be ordering some parts soon.
/ Tranny Fluid #8
I wouldn't run it with out the strainer
/ Tranny Fluid #10
Here is Hoye's diagram.
The outer surface of the 'strainer' (Yanmar's name for it) faces the transmission sump. Then on the forward 1/4 of the filter assembly, there is a shoulder and an O-ring that separate the sump from a little cavity at the front of the transmission where the pump intake line is attached. The large holes in the filter assembly forward of that O-ring let fluid pass from the clean inner side of the filter over into to the pump pickup cavity.
/ Tranny Fluid
I get it now. Thank you...I wonder how long this thing has been torn up.
/ Tranny Fluid #12
I discovered a previous owner used the wrong O-ring and this had cemented that filter solid into the transmission. I destroyed the filter tuggin it out all bent. (Photo).
That was back in 2003. After I sorted out the 'deferred maintenance' issues it has been trouble free ever since. Your result should be the same.
I suggest flush the transmission sump with diesel and scrub it with a toothbrush on a stick or something then mop it dry while you wait for the new filter. Then the new filter should be good for years.
/ Tranny Fluid
Do I need to take off the top cover to get in the tranny or scrub it through the 3-bolt access panel?
/ Tranny Fluid #14
I just poured diesel in the fill plug assuming that any sediment would be in the bottom inch and would be flushed out by this.
You can reach in pretty far via that bottom hole, clear to the back of where the strainer rests. I think I used a round slender parts brush, or maybe an old baby-bottle brush. A rifle bore cleaning brush would work too. This is to dislodge any sludge so that diesel can flush it out. Then test cleanliness with a rag wrapped around a stick.
(Note my edit to my post of a few minutes ago - photo added).
/ Tranny Fluid #15
it probably got ripped up with the gungy fluid trying to be dragged through it. that old oil has lots of water in it and has for a long time. even after a diesel wash i would run fluid for about 20 hours then replace it whilst hot just to be sure as you may find one day it has done some damage.
/ Tranny Fluid #16
I was referring to the hydraulic filter. My 186D has one.....maybe your model doesn't??? As for the screen......I wouldn't run without it either. As long as you're ordering parts.....might as well change all the fluids and filters.....seems like the previous owner may not have kept up on maintenance. At least you'll know what's in there!
/ Tranny Fluid #17
I had a feeling that is what this one looked like at one time. This would be a typical On The Cheap VN. Repair to me and it was complete with Forma Gasket instead of a O-Ring also. I decided best just to replace it.
Carey
/ Tranny Fluid #18
He has one of the newer powershift models, they have a spin on hyd. filter like more modern tractors do.
If you rin it without the screen it wont be any worse than that one prolly, but it will suck pieces of metal and circulate anything that may be there through your pump, which can cause extra wear and also stick your 3pt valve open. Id wait and get one from Hoye with the gague or sensor that you needed. If you fill it and run it with the old one you will ahve to drain the whole thing again to put the new one in, if you catch it in a clean bucket no big deal but i would not use your normal drain pan.
/ Tranny Fluid
Got it...Thanks for all the info guys.
/ Tranny Fluid
I got a 5 gallon bucket of "Traveller Premium Universal Tractor Transmission/Hydraulic Fluid" with the tractor. Is this fluid compatable with the recommended JD303 fluid? I cannot see the viscosity level on the label.
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
PORTA POTTY (A67714)
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
