shaving mill
/ shaving mill #1
tboomz
North Carolina
'59 IH 560D, '64 Farmall 140, '46 Farmall H
hi all,
new member here.
have seen how hay balers can be repurposed as wood splitters. But am wondering if anyone has ever tried to remake one into a shaving mill?
I've not seen the undersides of these mills. Do they use cutting heads like on shop planers or single blades a la hand planes?
/ shaving mill #2
hi all,
new member here.
I'm not familiar with the term shaving mill. What are you doing with it?
/ shaving mill #3
I'm fairly sure they use fixed blades.
That is to say, fixed blades are the only way I can figure they can get the long curly shavings.
Horse owners seem to LIKE the long curly shavings, although from an absorbancy POV they are probably much worse than sawdust.
Long and curly is a "product attribute" that can be marketed.
The customer being always right, , , sell 'em whatever they'll pay for (-:
Ahh, just remembered; search for Salsco, they're the local (New England) manufacturer.
Look at the power options on their SMALLEST machine.
I know little to nothing about hay balers, but doubt that they are built to absorb the sort of pushing and shoving that a machine using an 86 HP diesel would experience.
IOW not in the same (power) league.
BICBW.
/ shaving mill #4
:welcome:
tboomz
The shaving mills that have been demo'd at the recent logging shows have been very similar to a jointer (or planer) head with rotating blades.
The wood is loaded in a sliding magazine (box) that is powered back and forth over the rotating head. On some, the shaving planer head moves back and forth.
I am thinking you are thinking of using the baler plunger to power the magazine back and forth over the head. Might work.
No comment on the long curly shavings. :confused3: :)
Here is a vid link to one of many shaving mills.
http://www.youtube.com/watch?v=RpJkH-K8dm8&feature=player_embedded
/ shaving mill #5
Nope, that CMS thing is little more than a planer - aka a chip maker.
Shavings mills produce VERY LOOoooooNG "Shavings", not chips.
/ shaving mill #7
Yes, like planer shavings. Those are shavings. It is becoming a big industry, with bio fuels in the possible future.
Not sure what/where you get the Loooong shavings idea from. There is excelsior that are Loooonng strips/curls of wood, but very special machines to make it. Also, there are flake mills for making flakeboard. And mills that make strands of wood fibers.
Reg
Pls. put up some pics or links to what you are referring to here.
/ shaving mill #8
Reg
OK, if I have a camera with me the next time I am at a barn that uses long curly shavings I'll take a pic or two of the floor.
I usually DELIBERATELY leave my cell phone in the truck when handling horses, but I can probably find a clean empty stall somewhere and not spook a horse with camera flash (-:
/ shaving mill #9
As a wood turner, whenever I turn a bowl from green wood, I can generate a large pile of curly long shavings quickly. And this with only a 1 horse motor to turn the wood.
John
/ shaving mill #10
Hey guys, I don't deny that one can make curls and long strands of wood fiber. As said, a hand plane used along the grain will turn them out, as will a lathe when turning wood, as will special wood block slicers that slice along the grain of wood (they use these curls in hollow-core doors to separate the two plywood faces). There are also some wood chunkers that will have varying size screens, like a hammermill to knock wood apart and break it down into different size pieces.
I'm only saying the commercial shavings are being produced largely by shaving machines being marketed that have a head with knives very similar to a jointer head or a planer head. YouTube has vids of many of these machines. And I think, but don't know, that is what the OP is asking about.
/ shaving mill
yeah, basically I'm interested in the longggg shavings. but not like the excelsior that you find in packaging - too stringy. I figure that a rotary head will give something akin to sawdust shavings. I've walked on both types and the long shavings tend to feel "springier". I can see why horse folk prefer it. I got a dump truck load of stable bedding once and I like how it seems to compost better.
The one salsco i saw at a state fair put out short shavings. I was trying to figure how thin a blade to fix underneath , whether to have two in place to cut on both strokes, and would it work better shaving at an angle instead of perpendicular to log.
and rather than tearing the baler apart, just remove pickup reel and rake.
/ shaving mill #12
I think angled fixed blades maybe a couple of inches wide would peel off what you want.
You would need maybe 6 to 8 of them according to the width of what you feed.
Of course the block would tend towards one side, so the blades on that side would get the most wear.
You could probably figure out a cutter bar to mount the blades on and once built making another one for the reverse direction would likely be no harder.
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Caterpillar 14G Motor Grader Parts and Service Manual (A63117)
Caterpillar 14G...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
