oil psi ? ranch king tractor.
/ oil psi ? ranch king tractor. #1
gochenour799
Member
I bought a ranch king 25 HP 4x4 diesel tractor with a 72" finish mower to mow my yard with it had 70 hrs on it . It has a different style oil psi gauge on it than I am used to and I thought it was lying to me . So I put a autometer mechanical gauge on it. Here's my problem at start up it has 80 psi cold . The longer you mow the less oil psi I have 2 hrs in @ 2200 rpms I have 20 psi when I idle it down to shut it off I have 0 psi . I read about the bypass valve and adj. It . This only brought the cold psi up not the hot . I run rotella 15w40 and wix filters and change them often . I am thinking oil cooler maybe the next step ? Has anyone else had this happen ? I use the rule 10 psi for every 100 rpms is that too much for this application? it just worry me to idle it down to shut it off .
/ oil psi ? ranch king tractor. #2
Oil pressure is discussed quite frequently, so the answer to this is probably reasonably simple. But I need something cleared up first. You're giving pressure in psi (SAE), yet every Chinese oil pressure gauge I've seen is graduated in MPa (metric). Are you converting metric to SAE for purposes of posting? Or does your tractor actually have an OE gauge that reads in psi?
//greg//
No like I said in my first post I.don't trust that gauge so I installed a mechanical autometer gauge that reads psi
/ oil psi ? ranch king tractor. #4
80 psig is way too much for a cold startup with a multi grade oil. I would calibrate your test gauge for accuracy.
The other symptom you describe as losing oil pressure as the engine warms up suggests worn out camshaft bearings or crankshaft main bearings.
/ oil psi ? ranch king tractor. #5
Lets break out the calculator and do some math. You say, 10 psi for each 100 rpm.
At 2,200 rpm x 10psi/100 rpm = 220 psi. I dont think so!
How about 1psi/100 rpm.
2,200 rpm x 1 psi/100rpm = 22psi.
Now some questions, what does the OEM pressure gauge indicate?
What is the coolant temperature?
22psi= 0.151 Meg Pascal.
As for the pressure relief valve, it limits the maximum pressure and has no effect on the operating pressure.
At 80 psi you risk blowing the crank shaft oil seals. What is the rpm that gives 80 psi?
Is this tractor new under warrantee? Maybe talk to the dealer?
/ oil psi ? ranch king tractor. #6
Sorry, when you said "It has a different style oil psi gauge on it than I am used to", I thought that meant you didn't understand the metric gradients on the OE gauge. So yeah, a cold 80 to a hot 0 is considerably out of the norm - if it's truly accurate. It might not hurt to get an opinion from a 2nd mechanical gauge. Some folks couldn't cope with the metric pressure indications and went to mechanical gauges like you. Others learned to understand the OE metric indications by converting to psi on the fly. Out to the closest half pound:
0.1 MPa = 14.5 psi
0.2 MPa = 29.0 psi
0.3 MPa = 43.5 psi
0.4 MPa = 58.0 psi
0.5 MPa = 72.5 psi
So if what your mechanical gauge is telling you the truth, the OE gauge had to have been pegged during a cold startup. Is this correct?
Most owners report cold startup pressures with 15W40 are typically between 0.3 and 0.4 MPa, hot idle pressure is safe down to down to about 0.05. Operating pressure at temperature at speed should hover between 0.2 and 0.3
Which oil filter are you using?
//greg//
U
Your right 10 psi was a mistake . I ment 1 sorry . Rpm @80 psi is idle @ start with cold oil , as soon as it starts to warm up the oil psi drops .
the own gauge says the same thing pegged @ start up 0 @ shut down .
No warranty , no help its a rual king tractor .
Water temp is fine and I never have had it hot .
0.1 MPa = 14.5 psi
0.2 MPa = 29.0 psi
0.3 MPa = 43.5 psi
0.4 MPa = 58.0 psi
0.5 MPa = 72.5 psi
//greg//
I understand it I just didn't trust it , but it shows the same thing as the new one.
/ oil psi ? ranch king tractor. #9
Again please, which oil filter are you using? And not that Rural King ever did much better, but they sold their rebadged Jinmas as Tractor Kings, I don't know who sold Ranch Kings
//greg//
/ oil psi ? ranch king tractor. #10
Hate to say it but you may have a spun & locked crankshaft or camshaft bearing. If the issue isn't resolved with the oil filter, then I'd plan on dropping the oil pan. :( I recommend performing an oil analysis.
//greg//
It's a red Baldwin filter sold @ rual king
If it is a bearing wouldn't it have low psi all the time . Not after 2 hrs of work ? It starts @ 80 then slowly drops to 22 psi @ 2400 rpms after running for an hour . But @ idle has less than 5 when oil is hot . As of today it has 106 hrs and I have put 36 of those on it . I change the oil every year . I have owned it for 5 years . It's like the oil gets so thin the pump can't built psi . Idk I need to put a oil temp gauge on it . It runs and sounds fine it starts great when its warm out . It doesn't like cold weather starts ,but once started it runs fine.
/ oil psi ? ranch king tractor. #13
A bearing that has spun and locked did make a sound at one time but wouldn't necessarily be discernible after that event. The number of hours and the quality of the lube oil are somewhat irrelevant as to the cause. What is at issue is the metallurgical quality of the bearing in question - in the case of the crankshaft bearing, the indexing tabs - in the case of the camshaft bearing, the interference fit. A bearing can spin without seizing on a shaft permanently (welding itself) and partially or completely block an oil passage causing very high back pressure, to the point of popping the relief valve on the pump, but yet still pass enough oil to the rest of the bearing through "wire drawing", to prevent complete seizure. A diesel engine would sound quite normal operating under these conditions. The subtle knocking of the crank journal could be easily mistaken for and masked by detonation sounds. There are instruments available that can detect and isolate those sounds and vibration frequencies. An oil analysis will give you some real good information so you can make an informed decision in which direction to proceed.
My guess is that after two hours of brush-hogging your engine oil is very hot - hot beyond viscosity stability.
Greg wants to know the number on the red Baldwin filter. :thumbsup:
/ oil psi ? ranch king tractor. #14
Ok, but I'm pretty sure Baldwin makes more than one filter. So let me try one more time. What is the Baldwin filter number ?
//greg//
//greg//
Idk the # . I will have too look and I won't be able to do that till next week as I am not home for a few days . Thank you for trying to help me . I will get back to you . I know its very hard filter to get and expensive .rual king is the only place I can find it. I took it to a auto parts store and they could not cross ref. It with anything the can get. Even from their Baldwin book ,I would like to use a wix . Tell me what filter I should be using and I will get one and change it .
/ oil psi ? ranch king tractor. #16
It's not a Baldwin if it isn't in the Baldwin book!
/ oil psi ? ranch king tractor. #17
I have been using a Fram PH3950 for years on my tractor. I have also crossed it over to Wix, STP, Napa, ect. Just get whatever they have where I am at.
Anyway, Fram PH3950 is the number I start with.
For future reference here are the numbers I have used since 2003.
Air= Purulator A42019
Oil= Fram PH3950
Fuel= Fram P6503
Chris
Oil= Fram PH3950
Fuel= Fram P6503
Chris
Thank you this is a big help
/ oil psi ? ranch king tractor. #19
I have the 4 cylinder version of your engine, but they share a lot of common parts - including filters. Since the only parts store in town is a NAPA, I use
oil Filter - NAPA= 1516
Fuel Filter - NAPA= 3195
Air Filter - NAPA= 2276
And someone put together a pretty handy list a few years back; see below.
//greg//
//greg//
Thanks do u think if I change filter brands it will solve my problem
? Where do you go for parts , if I have too do a bottom end.
