odd FHA question
/ odd FHA question #1
20 20
Elite Member
adirondacks
I have a question about FHA requirements for heat sources. From everything I can find I should be okay with my pellet furnace, but they seem to have their heads in the clouds. From what I have read it says The heating and cooling system must have at least 2 years of remaining life.
Wood stoves or solar heating are not acceptable as the sole heat source. NOTE: Coal or wood stoves with automatic stokers are acceptable
. According to this statement a pellet "furnace" should fall into the category??? Anyone know where I could find any info out about this? Thanks
/ odd FHA question #2
hummm your pellet stove has an auger right? wouldnt that be automatic?
We have electric baseboard heating, but our wood stove is supplemental....that being said the electric is at 50 all winter long, and inside is a toasty 70+ with the wood stove.
/ odd FHA question
Yep Forgeblast; That is what I figured, it also has the big hopper, I can't seem to make the FHA person relize this. I figure because the FHA person lives in the city and is more then likely on natural gas or electric they don't know booger about wood or pellet stoves. Of course that shouldn't really matter when they're looking at the requirements in front of them. I'm just frustraited because they're not using their own guide lines. My house stays right around 80-85 all winter with just the wood furnace. I bought the pellet furnace and a small pellet stove just for back up when I'm not going to be around. The pellet furnace can also keep the temp up in the 80's if needed. I'm lost, they set these regs then dodge them or change them for whatever they feel their personal needs are :confused:
/ odd FHA question #5
I think the problem with FHA is that they want a heating system that "any Joe" can use in case they have to foreclose on your home and sell it. With the primary heating source being a wood furnace or pellet stove it would be hard to sell your home in a foreclosure. They would have to go in (spend money) and put in an "automatic" heating source. IE: Furnace or Heat pump.
Chris
/ odd FHA question #6
What do the county tax records say about your heating and cooling sources?
/ odd FHA question
You mean your wood furnace? R i g h t.......
I have both a wood furnace and a pellet furnace. With my wood furnace I have to load it every so many hrs by hand. I do use the wood furnace 90% of the time.
I also put in a pellet furnace and a small pellet stove{both have a thermostat}, my confusion is about the pellet furnace. It seems to me that a self feeding pellet furnace would fall into their requirements,.,.,.,.NOTE: Coal or wood stoves with automatic stokers are acceptable{this came from their requirements listings}?
Hope this cleared it up some, I put the pellet furnace in for times while no one is home to tend to the wood fire. It can run for 5 days without any interaction from us, and keep the house in the 70's{on the coldest days}
/ odd FHA question
Chris
This is what I have
Pellet furnace for primary heat..... while no one is around or able to load wood in the wood furnace.
Wood furnace is main source of heat because our wood is cheap and usually someone is around to load it.
Pellet stove just for those days when it isn't worth it to start a fire nor run the big pellet furnace. Basically just to get the chill out.
Chris you may be correct about the heating system, BUT the requirements do NOT have anything about that, all they list is what I've put in blue about my type of heat source.
Well had to take a minute{phone call}, just talked to the FHA person and basically what they told me is that it lys with the person in charges opinion. :mad: :mad: :mad:
/ odd FHA question
I wonder why we waste time to write up requirements and regulations when in the end all we do is go with whomevers opinion? Kind of like saying it's against the law to drink and drive unless you do it while phil is on duty :mad: :mad: :mad:
/ odd FHA question #11
Of course, If I'm the one on duty, you have to share and then neither of us will do any driving .
Phil
/ odd FHA question #13
I'll bet that the stove mfgr will be able to get you a letter or some specs to show that it fits into 'automatic' category. Give it a try.
/ odd FHA question #14
Not sure what you mean Riptides?
My county tax records listed electric base board heaters instead of HVAC systems.
The FHA people had a ball with us, over this.
If your county records list something favorable for your position, can you use that against the FHA opinion?
Also, don't you need an in-person appraisal? They may be able to help you too?
/ odd FHA question
Thanks
The person that did the appraisel made a bunch of mistakes which has caused even headaches.
/ odd FHA question #16
Well I think FHA requires two appraisals. Document everything and make sure the next one gets the right information.
/ odd FHA question
My wife just talked to them this is their personal choice, they kept saying it was an FHA regulation, but finally admited it is not :mad: Seems like the underwritter doesn't care for pellet or wood stoves of any type and has real issue's with them :confused:
I feel like I'm surrounded by a rock a hard place and a pile of $*&# not sure which way to turn. I will take your advice thanks
/ odd FHA question #18
I went through an FHA process about 10 months ago. I had to have the mortgage broker step in and set them straight. It pays to ally with the lender/banker. I can share my details in a PM if you need them....
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
