Tool To Cut PTO Shaft.??
/ Tool To Cut PTO Shaft.?? #1
JDGreenGrass
Maine
John Deere 770
What have you used to cut a PTO shaft.??
I have a 15 gallon air compressor....Is there a sort of a cutting disc I could buy.??
Thanks.
/ Tool To Cut PTO Shaft.?? #2
Could use a metal cutting band saw, abrasive cut off saw (chop saw), reciprocating saw with metal cutting blade as possibilities. Air driven cut off blade would also work but would probably take the longest and require more blades. The finer the cut the better. An abrasive cut off blade would require more filing on the edge when done compared to the others but probably the fastest.
/ Tool To Cut PTO Shaft.?? #3
die grinder with a cut off wheel would work, however with a small 15 gallon compressor, depending on the compressor's cfm rating, you'll probably have to stop to let air pressure build up. Check the cfm usage rating of the tools, and compare it to your compressor's cfm rating.
A better solution might be an electric cutting tool, hand grinder w/cut off wheel, reciprocating saw, or a portaband.
/ Tool To Cut PTO Shaft.?? #4
The PTO shafts are made out of fairly soft metal so it is something that could be handled by a hand hacksaw. It will take awhile and use up a blade but it works on the cheap.
Another option I've seen is to cut it with a torch and grind the end until the resulting slag is gone.
My choice is a sawsall with a metal cutting blade like used in a hacksaw.
Thank you.
I do have a sawsall on hand so I guess I will give that a go.
I've got to do the math again and then act as a carpenter....measure twice, cut once.:D
/ Tool To Cut PTO Shaft.?? #6
I used a cheap ( $69. ) radiac metal chopsaw with a 12" disc acquired at HF years ago and after you have one ...... you wont use a hacksaw again.
You could also use a 4.5" angle grinder with a cutting wheel. I just bought one from Northern Tool for $29. that comes with the cut off wheel , grinding stone and sandpaper discs. Cheap ..... but it works very well for the novice like myself.
/ Tool To Cut PTO Shaft.?? #9
Saws All with hack saw or metal cutting blade will waltz right through it. Clean up the edges with a file. Easy.
/ Tool To Cut PTO Shaft.?? #10
Thank you.
Do a search on You Tube ..there is a good video on their showing exactly how to cut a PTO shaft ..including the Math and that is really important...just search cutting PTO shaft...it should come up.
/ Tool To Cut PTO Shaft.?? #11
This is what we used for my dad's Caroni flail mower PTO shaft, & it took probably 60 seconds each. A "cut-off" disc I think it was called. Ripped right thru it.
You know you have to cut the end off both shaft sections, right?
/ Tool To Cut PTO Shaft.?? #12
Cut mine with a 6" Metabo. Took longer to mark than to cut.
/ Tool To Cut PTO Shaft.?? #13
Once you use a horizontal bandsaw, you will unplug that chopsaw!
No metal sparks in your eyes or burns on your skin from flying sparks that will ruin bearing surfaces. (such as ways on a mill or quill on a drill press)
David from jax
/ Tool To Cut PTO Shaft.?? #15
I used a chop saw at my Dad's shop. All I had was a rechargeable reciprocating saw and it just was not up to the task. You could pay $5 or $10 at any muffler shop and they would be glad to cut on your mark.
/ Tool To Cut PTO Shaft.?? #16
And I have been to Blair, Ne...!!! Good times for sure!
David from jax
/ Tool To Cut PTO Shaft.?? #17
David from jax
Its a great little town. Needs a Taco Johns and Arby's though. Fast food selection is very limited.
/ Tool To Cut PTO Shaft.?? #18
i just used my band saw ... i was worried that the sawzall would just make a mess of it (long blades)
/ Tool To Cut PTO Shaft.?? #19
Doesn't need anything in the way of lakes or women. Stories of the trip made it to Florida just before my wedding and almost caused it to end before it started. Any place you can talk six women into getting into a two seater car and then taking you home is a GREAT Place to visit. The stories could go on, but my wife probably would not appreciate me putting them on the net.
David from jax
Thanks for the replies everyone.
I used a Sawzall to cut the pto shaft. It worked great.:thumbsup:
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2010 Deere 318D (A60462)
2010 Deere 318D...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59912)
2011 GREAT DANE...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
