error code
/ error code #1
toolcat86
i have an 09 toolcat 5600 with 19hrs on it and im getting error code 50-47 and it wont start does anyone have any idea what this might be
/ error code #2
50-47: Two Speed Error On
I notice in the troubleshooting flowchart that "Replace Drive Controller" appears a couple of times...amongst other stuff like "check wiring harness". More details can be found in the service manual...but since I presume you are under warranty I think I'd call the dealer. If possible, I'd leave it dead right where it sits and let them figure out how to load it.
/ error code #3
Code : 50-47
Description : Two Speed Output Short to Ground
Sounds like an electrical problem. I thought I had a diagnostics manual for this unit but apparently I don't.
DEWFPO
/ error code
thanks for the help and i would let it sit as normally it would be under warranty but im in southwest asia deployed and we have no bobcat dealers anywhere so any help on how to fix this would be appreciated
/ error code
do you happen to have a digital copy of the trouble shooting flow chart?
1604 (A57192)
1604 (A57192)
2011 GARDENER DENVER TRI PLEX FRAC PUMP (A60736)
2011 GARDENER...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
