Fuel consumption on L3400
/ Fuel consumption on L3400 #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
How is the fuel consumption on a L 3400 compared to a Large B series.
/ Fuel consumption on L3400 #2
My L3400 seems to like burning the fuel. Compared to my old Case IH 1140 that was about 10 less hp. I have spent some time on my uncles B2920 mowing with 5ft finish mower and I will say that my L3400 burns way more fuel mowing with my 6ft finish mower. Both machines are HST. More power equals more fuel is the way it goes.
/ Fuel consumption on L3400 #4
I think I am doing a little better than that, maybe 3/4 gal per hour. but mostly loader work not mowing. so variable rpm and not as high.
James K0UA
/ Fuel consumption on L3400 #5
Our L3600GST seems to burn just a touch more that 1.25 gal/hour when running a 84" Befco finish mower. After mowing for 3 hours, 3.75-4 gals tops off the tank vertually every time (thats with running the A/C). Even the little BX2230 will burn just more than 1 gal/hour mowing with the 60"mmm.
More power doesn't always mean that you will burn more fuel. For instance our F350 4X4 7.3L, when it was bone stock mileage running empty was 16-16.5, now with lots of modifications and 425hp/900+lbft to the rear wheels the truck pulls down 19-20 mpg if your nice on the throttle. This is because the motor doesn't have to work nearly as hard to do the same amount of work.
/ Fuel consumption on L3400 #6
I haven't been able to measure my fuel usage with any exactness yet, but my tractor was delivered with "about" half a tank and ran over 8 hours of mowing before I added any fuel. I am only at 13 hours now and have not used the next 5 gals yet.
/ Fuel consumption on L3400 #7
I get about 1 gal per hr. avg.
Mine is about the same mowing moderate fields with the rotary cutter. I get a bit better doing loader work, but that's a safe number for the 3400. I doubt you'd use much more than that unless you had some serious load all the time.
Sean
/ Fuel consumption on L3400 #8
Three hours of finish mowing (Woods RD7200) takes about 3.5 gallons on my L3400. That's mowing my big yard which I let get to about 5 or 6 inches before I mow. That include backing up a lot for about 40 trees.
2020 CATERPILLAR 259D3 SKID STEER (A65053)
2020 CATERPILLAR...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2012 Ram 1500 Crew Cab Pickup Truck (A64556)
2012 Ram 1500 Crew...
