HST/ PTO SPEED
/ HST/ PTO SPEED #1
First one
Gold Member
Eastbrook, ME.
08' Kubota L3240 HST /cab
If your tractor is rated at 32hp (HST) and 25 hp at the pto is that all the time, even if the tractor is sitting still using ,like a winch? or is it diff. like running a mower with the tractor moving? By moving in the tractor does that change the pto hp or by keeping it at 540 gives you the 25hp?:confused2:
thanks Scott
/ HST/ PTO SPEED #2
Someone on here will be able to give a more precise and technical answer, but my understanding is that HP is a function of RPM. When you operate your engine at a reduced RPM level you will see a corresponding reduction of available HP. As long as the engine is running at the required RPM, it does not matter if it is stationary or in motion.
I do not know if the rated HP of the tractor is at 100% RPM or at the PTO 540 level. I do believe it should be very close at that point if not fully at the rated HP. I do think that the rated PTO HP is when the engine is operating at the PTO 540 RPM.
/ HST/ PTO SPEED #3
I think with a hydro transmission the pto is independent.??
So, I think your pto will always be rated 25pto hp, though don't take my word for it.
Man, I wish I had 25ptohp. I got 20ptohp.
/ HST/ PTO SPEED #4
Any maximum HP is given at a set engine RPM, this should be in your specs. No engine has a flat power curve or none that I know of.
HP/PTOHP does not change between stationary and underway, but "available" HP will as some is being used by your transmission.
/ HST/ PTO SPEED #5
Just to be a little more clear, the PTO HP will vary from 1 HP to the rated PTO HP, based on engine rpm. I have seen people run their bush hog at half throttle, and they can cut some things well, but when things get rough and tough, they have to use full engine rpm, and therefore max available engine HP. Some PTO's also run at different rpm's for certain attachments.
/ HST/ PTO SPEED #6
I think the OP was wanting to know if the PTO HP would change base on the engine running multiple things. For example, if the tractor is not moving ALL of the engine HP is being fed to the PTO... whereas if the tractor is moving, the engine HP is being fed to both the PTO and the tractor's drivetrain.
My GUESS would be that the PTO HP would vary based on what I said above. RPM obviously varies the HP output... but I would think the multi-tasking of the engine would also affect how much power is routed to the PTO.
/ HST/ PTO SPEED #7
That is correct.
Your engine can only put out a certain amount of power, and do only
a certain amount of work.
If an engine can put out 32hp at the crank, it has to work to turn all those
mechanical and hydraulic bits before it can turn the PTO. If you are
asking the engine to turn the wheels, too, that takes more power. And,
an HST tractor is always pumping oil thru the charge pump whether the
tranny is turning or not.
Bottom line is if you are driving along at full RPM and driving up a hill
that takes 15hp, your PTO will have only something like 10hp available to
mow that grassy slope.
/ HST/ PTO SPEED #8
Only a guess:
The stated PTO HP figure must be a max figure, otherwise, taken to an extreme, owners could damage their implement(s) not rated for an occassionally higher HP figure, possibly hurting themselves, & opening the tractor manufacturer up to potential lawsuits.
I suspect OP's 25 PTO HP is a best-case scenario, i.e. true only when nothing else is drawing power from the engine (& of course when the engine is running at its highest output RPM). :2cents:
/ HST/ PTO SPEED #10
J_J said:
The standard tractor will have more PTO HP than a hydrostatic tractor.
I don't believe the drive train is figured in the ratings.
Reg this:
I was wondering where all his HP was going 32 - 25 seems like a big loss to me. I go from 28 - 25. But I have gears. :)7
/ HST/ PTO SPEED #12
thanks Scott
Hp is a bit more complex than RPM alone, there is also the matter of torque.
Torque x rpm / 5252 = HP
You can see that if you keep hp constant, as the torque increases the rpm's will decrease.
Keep the revs constant and hp follows torque.
Another way to look at it, set the engine revs for 540 rpm at the PTO with no load. The hp developed is 0 because the torque is 0. As the PTO is loaded only the torque will change, increasing to meet the loading and hold the revs at 540.
At some point, the PTO revs will drop as the load is increased, this is the point that the engine can sustain the rpm's and torque that will produce maximum hp under those conditions. In your case 25 PTO hp @ 540 rpm.
/ HST/ PTO SPEED
Thanks for the help:thumbsup:
Ok ,one more thing ,whats the deal with gross hp which is 34hp and net hp which is 32hp?
/ HST/ PTO SPEED #14
Net horsepower ratings is the measured output on an engine with all peripherals attached. Hyd pumps, alternator, water pump, etc.
Gross HP is measured at the engine flywheel..
/ HST/ PTO SPEED #15
gross hp is what they charge you for and market the tractor with. Net hp is what you have available to do work with after you buy it.
/ HST/ PTO SPEED #16
Sort if like on your paycheck, first thing you see is gross, and at the bottom is the net after all the deductions are taken out for the government.
/ HST/ PTO SPEED
Well, that cleared that up fast ,you never get all you pay for or work for I see even in the tractor world :( thanks again!!
/ HST/ PTO SPEED #18
not how that works.. ind pto is just ind of the drivetrain or dt clutch.. engine rpm still dictates pto speed and hp..
soundguy
/ HST/ PTO SPEED #19
Note that Kubota went to net hp marketing a while back. Your L3130
has 31 net hp, while gross is 32.1hp. Most tractor makers don't do
it that way....kudos to Kubota.
BTW, your tractor makes 25.5hp at the PTO, unless you have a HST;
then its only 24hp. 1.5hp is to run the charge pump.
/ HST/ PTO SPEED #20
Sadly, you are close but not all the way there.
Gross hp is how much the engine makes, typically with no alternator, intake filter or muffler. Just the engine, best case. Net hp is what the engine makes as it sits in the tractor. It's not useable as it has to go through a transmission/differential or hydraulic pump before it can be used. PTO hp is the amount you can use at the pto (obviously!). It's about 5-8hp less than the net and 7-10 less than the gross and is impacted by drive line losses. Drawbar hp is the amount of pulling work you can do. It's impacted by both driveline losses and geometry / traction. It may be a bit more or less than PTO hp depending on the machine. A heavier machine will have better traction and more drawbar hp than a lighter machine with the identical engine.
The real hp numbers you should compare are either drawbar or PTO hp depending on what you will be doing with the machine.
So the better statement is that Gross HP is what they charge you for, but PTO (or drawbar) hp is what you buy.
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
