Deere 4115 compact
/ Deere 4115 compact #2
I have it's baby brother, the 4110. The 4115 has a 24 HP direct injected engine vs. the 20 HP NA in mine, plus a slightly longer wheelbase it's the same machine.
Good, solid machines.
Kenny, thanks. How would you rate them for grass mowing? Is the "72" deck a good deck? Are they comfortable for long mowing missions?
/ Deere 4115 compact #4
Anyone own one? Found a used one with 72" deck 750 hours. Price seems good. It's at a Deere dealer, so I can great a great financing package on it. .
I had a 4115 and I loved it! Wish I would have kept it.
/ Deere 4115 compact #5
I looked hard for one but time got in the way and I settled for a 2210. Kinda wish I'd kept looking...
/ Deere 4115 compact #6
The 72 is a great deck, it will do well on flat area's. The seat is OK, could be better, but it could be a lot worse also. It will have no problem mowing in high gear either. Get the SN, and call a local dealer to get the service history.
UGH! Now the dealer is saying I can't add remotes to the rear because they were a "factory ordered option".
Is this true? How could it be possible that no remotes could be added after the tractor is built? :confused:
Is the "72" deck tough enough for light commercial?
/ Deere 4115 compact #8
Factory remotes no, but you can add them yourself by tapping into the Power Beyond line. I and many others have done it.
Yes, absolutely.
/ Deere 4115 compact #10
Thanks, Kenny.
Any idea (roughly) of cost to add remotes from PB circuit? Or loader valve for that matter?
OK, Just answered in the PM...tired of typing the same answer twice;)
About $500 aftermarket, plus you will have to fab all the mounting...probably 3x that for the OEM.
/ Deere 4115 compact #11
I have one with a 60 inch deck. Its a 2005 that I bough in 2007 used with 32 hours on the clock. I now have around 280 hours on it without any major problems. I did have a leaking hydro line fitting that cracked from vibration. Its a strong tractor. Hopes this helps if you need more info just ask.
Guys, thanks for the replies. I had to settle on a local dealers used BX2200. Not as much tractor as the 4115, but $3,000 cheaper and more quickly delivered.
Good luck with the 4115's. That was a great "fit" for me. :thumbsup:
Ford F-450 (A63118)
Ford F-450 (A63118)
New/Unused Electric 3-Wheeler (A61166)
New/Unused...
2006 GMC Savana 3500 Box Truck (A61568)
2006 GMC Savana...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A61165)
2005 Hino 268...
WHEEL BARROW (A62131)
207273 (A52708)
207273 (A52708)
