Changing oil in injector pump-FarmPro 2420
   / Changing oil in injector pump-FarmPro 2420 #1
MisterJim
I am past due to change the oil in the injector pump on my 20 hp 2 cyl,
FarmPro 2420. I believe I need to remove at least one or is it two bolts from the bottom of the pump housing to drain the old fluid. Is this correct? Then when I refill it; where do I put the new oil in? Is it the spring-loaded cap for the primer pump that I remove and then pour the new oil in there?
Sorry for the basic questions but I am new to diesel engines (and Chinese tractors!!)
Here is a picture of my injector pump.
   / Changing oil in injector pump-FarmPro 2420 #2
The oil will drain from teh botom of the governor portion of the inj. pump at its lowest point. you can fill it by removing the vented cap, behind the throttle lever in your picture, on the top of the governor housing.
Bluechip and Willl, Many thanks for your response! Now I know exactly what to do and even what size socket or wrench to use......you guys are awesome!! My nearest dealer is about 120 miles away so if I don't fix it myself; it's a real problem to tow it down to him!!
Well I am really confused now! I cannot find any drain plug on my injector pump. My FarmPro 2420 is a 2004 model with a TY290 2cyl. 2WD and power steering. I bought it with 100 hours on it and now it has 295. I am embarrassed to admit that I didn't know the oil needed changing in the injector pump until recently.
I had a small hydraulic leak that I fixed with new washers so I also changed the hydraulic fluid and refilled with fresh AW32. Started the tractor to test the hydraulics and so far no leaks and all is working just as it should.
Then I decided to go for the injector pump and I cannot find a drain plug anywhere. I did pull the dipstick and some fluid squirted out when I pulled it and it seems to be fresh clean hydraulic fluid. Is my particular engine one that lubricates the injector pump through the engine somehow??
Anybody have any thoughts on this??
Like I said, the tractor starts quick, idles nice and has normal power and all systems are working as they should!!!
   / Changing oil in injector pump-FarmPro 2420 #6
I am not familiar with your tractor but the pic above shows a 13 mm wrench is needed for the drain plug. I know my 284 has 2 drain plugs on the injector pump. Keep looking at the pic and go back out and look at the pump again.
If oil came out and was that thin its diluted with diesel fuel. That is why you change it regularly. Some fuel will get into the oil over time. Most of us change the oil in the pump every 100 hours or every other oil change for that reason alone.
Chris
Chris, The picture you are referring to is the one that Willi posted but my tractor must not have the same style because there is no 13mm or any other size plug in the bottom of mine. I know now (after reading the posts on this forum) that the oil does get diluted and that's why I was anxious to change it.
So I am still at a loss as to how to drain it!!
   / Changing oil in injector pump-FarmPro 2420 #8
You have to be missing something. As far as I know all these pumps have drain plugs. Some of the newer ones are engine fed but if yours has a dipstick I highly doubt it is that style. Keep looking and run your hand around underneath it. Also a fresh set of eyes on the thing may find it right off the bat.
Chris
Chris, Thanks again for responding. I just came back from my pole building and looked again and I swear there is no drain plug of any size there. It's getting late but tomorrow I will take my camera out and take some pix of the bottom side of the governor assy and injection pump and post them.
I also checked Homier's website and looked at the picture of the pump assy for the TY290 and it definitely shows a drain plug at the bottom but mine looks almost the same but it's definitely a different design. I also looked at the engine ID plate and it shows the engine was made in 1999/08 but the ID plate on the inside left rear fender shows a date of June 2004. I read somewhere on here that they sometimes stockpiled engines or cheated on the mfr dates to get past EPA regs. So who knows when my engine was built!!
   / Changing oil in injector pump-FarmPro 2420 #10
If I had to find mine from the side - visually or by feel - I'd say the same thing. I can only see it from under the tractor, lying on my back - looking up.
Good chance your engine was made the same year as the tractor. If anything was stockpiled (or falsified), it was probably the engine labels. Some call it a loophole, others call it dishonest. Either way, that's how the Chinese took advantage of a temporary EPA Tier III exemption from 1999 to 2003.
//greg//
   / Changing oil in injector pump-FarmPro 2420 #11
The only other suggestion I can make to get most of the oil out would be to warm up the tractor then try sucking the oil out of the dip stick hole with a turkey baster or large syringe and a piece of hose. That would be better than nothing. Its still going to leave a little oil on the bottom and that is usually where the nasty stuff lays.
Chris
I crawled under the tractor with my camera and took a couple of pictures and hopefully you can see what I mean.....no drain plug!!!:mad:
I also looked at the side of the housing that faces the engine block and nothing there either. Didn't really expect anything but had to look anyway.:)
Chris, I was going to do just what you suggested (unless somebody comes up with a better solution) and take my wife's turkey baster and suck as much as I can out of it. I guess it's better than nothing but like you said...all the crud will be still at the bottom. Maybe I can do it several times after an hour of operation and catch it still in suspension.
In the meantime, thanks to everyone for offering help...I greatly appreciate it!
Jim
   / Changing oil in injector pump-FarmPro 2420 #13
Just like mine Jim, no drain, either on the fuel injection pump or the governor. I change oil using a Mityvac. Don't worry, it will suck the crud out too.
Bob,
Thanks for the tip....I have a Mityvac in my cabinet but didn't think about using it! I tried the turkey baster but couldn't make it bend enough to fit into the fill plug opening or the dipstick opening. But while I had it close to the fill port; I squeezed the bulb and it actually "blew" the old oil out of the dipstick hole. Not very scientific and not very clean but it did get most of the old diluted oil out.
But now I will dig out my Mityvac and use it per your suggestion. I usually use it just for bleeding brakes and haven't had it out in so long that I forgot I still have it!! After changing out all the fluids and using the tractor for a couple of hours yesterday; it's running very good and all systems are working fine.
Jim
   / Changing oil in injector pump-FarmPro 2420 #15
How much oil do you ,put in the injection pump and what kind of oil
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2003 Big Tex 10PI...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
