Threads on cylinder rod ends...
/ Threads on cylinder rod ends... #1
/pine
Super Star Member
Does anyone know if the threads on the average tie rod cylinders are universal? and what they might be?
I have a tie rod cylinder I got from Nothern tool....and to be able to use the same cylinder on a couple of different applications I would need to extend the length of the rod by an inch or two...
...I was thinking I might be able to use a threaded coupling (Galv. pipe maybe?) and a cut off bolt etc...the rod is 1-1/8"
/ Threads on cylinder rod ends... #2
use a thread pitch gauge on it..
are you thinking it is NPT? I noticed you mentioned a pipe coupling..
soundguy
just guessing/hoping...it looks like it could be NTP...
I'm ignorant of the thread pitch guage ???
I'm not opposed to using tap and dies although I have never worked with such large stock...
/ Threads on cylinder rod ends... #4
they cost like 5$ each for sae and metric.. lil feeler gauges with swing out wings with multi thread pitch feelrs on them you decide whay you got.. can get ID and OD gauges.. as well as bolt and hole gauges..
soundguy
/ Threads on cylinder rod ends... #5
9 times out of 10 it will be sae fine threads, the diameter of the threaded shaft. Ken Sweet
/ Threads on cylinder rod ends... #6
I am not sure what threads you are talking about. Are you talking about the hydraulic ports???? Cause them are the only ones that would ever be NPT. But they could also be and o-ring fitting as well and they are not interchangeable.
But it seems that you are talking about the end of the "rod" itself. The part that a clevis/yoke of what not would thread onto. These are most deffinatally NOT NPT. But they are likely fine thread by whatever the diameter of the rod is.
If you don't have/like a pitch guage, you can use a tap of even another bolt and match up the pitch just like a guage. Might not give you the diameter but it will give you the TPI.
Thanks, I will look for a pitch guage...sounds like a good tool to have...
the threads I'm referring to are on the end of the rod where the yoke threads on...
We have a local hardware store that just might have a SAE fine bolt in that size if I'm lucky...otherwise I might try cutting one myself...the coupler may be a different story...
if it becomes too much of a job I'll just spring for another cylinder and hoses and QD ends...
thanks for the replies
/ Threads on cylinder rod ends... #8
Typically rods 1.125 and up are 12 TPI......
IE: 1.125-12
1.250-12
1.375-12
1.500-12
If smaller than 1.125.....then it differs.....1.00-14.......875-14....... .750-16.......625-18......
/ Threads on cylinder rod ends... #9
do get the thread gauges.. they are cheap and sooooo usefull.
soundguy
thanks...this measured 1-1/8" (1.125)
Maybe I can find a local machinist that can turn me out a female/male extension ?
already have it on my list...do auto parts stores stock them ?
/ Threads on cylinder rod ends... #11
I'm a machinist and have several pitch gages, but if i need to know thread pitch and don't have a gage handy, I just use a scale or tape measure and count the threads in one inch. Don't count the first one you line you're scale up on. Metric is a little different story though. Metric is the distance from one thread to the next.
Kim
/ Threads on cylinder rod ends... #12
i got my gauges where I bought my tap / die / drill bits at.
soundguy
JCB 3TS-8T Compact Wheel Loader Skid Steer (A64553)
JCB 3TS-8T Compact...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
Swict 60in Bucket Skid Steer Attachment (A64553)
Swict 60in Bucket...
2022 EZ-GO ELITE...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
