Practical tips
/ Practical tips #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
a long long time ago there was a thread with some simple tips. I put one in there and it seems someone really liked it (I thought it was pretty simple)
Heading into cooler months I thought I'd mention it again.
Chainsaw bar oil: I buy a gallon jug. When I unscrew the top, I do NOT then pull off the seal on the spout. Rather, I take a screwdriver and simply punch a hole in the cover. now, I have a VERY controlled flow coming out of this little 1/4" hole rather than always overflowing my saw with oil. Yes, it takes longer to fill my saw but if you saw how often I used to coat my saw with oil you would see why I now do it this way.
Roundup: I have some containers of that (maybe 1/2 gallon in size?) and like the chainsaw oil, I punch a hole in the cover so I don't have the liquid coming out too fast.
Hearing protection: I have some of those Proear muffs (something like 29 db reduction?) In addition to using those, I have an Ipod with me and the ear piece for the Ipod alone helps knock out a lot of noise. I put the Proears over the IEM's and makes it even more quiet. I do not use the original Apple ear pieces, I bought some nicer ones with ear wire wrap from Klipsch. (Custom 3's which are now discontinued...but sound fantastic)
Feel free to add your own.
/ Practical tips #2
I have several but only a couple come to mind because I just used them; and everyone most likely already knows about them.
When drilling into concrete floor or wall for bolts that do not have the inserts. If the hole becomes too big for the bolt/lag then fill the hole with steel wool before screwing in the bolt. It will hold it very well.
You can also wrap aluminum foil around a machined bolt to help bind. I used this for a pot lid last night that the handle would not hold to the bolt.
I always use soap on wood screws or lag screws when needed with wood to easy assembly.
/ Practical tips #5
You have to be careful with punching foil seals so that a small piece of foil does not get into the tank you are filling. I use these on my bar oil jugs. They have several adapters to fit different threads and you can twist it to adjust the flow or shut it off all the way. They are about ten bucks for the kit. I removed the clear hose and just use the nozzle.
Hopkins FloTool 10105 Spill Saver Gas Can Spout
/ Practical tips #6
For stripped out lag bolts in wood you can put some wooden toothpicks and some wood glue into the hole, then put the lag bolt back in and tighten it down. It works pretty well. Just don't put in so many that you split the wood. :thumbsup:
/ Practical tips #7
Ah that old trick. :))). Works well on any screw into wood. Used it most often when rehanging doors.
/ Practical tips #11
I put my bar oil in a syrup bottle w/pop up cap. Works fine for me.
/ Practical tips #14
I reuse large kitchen dishsoap bottles with the pop tops. Fill them from the 1 gallon oil jugs. Much easier to pour out of, especially on my top handel Husky that partly blocks the oil fill.
One thing I never hear mentioned, is glasses. I am protective of mine, because I really need them. When I had my son in the 4H shooting program, they always wore safety glasses(good thing...!). The instructor had a saying:
"On your face or in the case!"
They sratch so easy, getting knocked around on the bench ect. So, the kids got in the habit of keping them in thier cases. And they lasted longer without scratches
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
Case Titan 3530 (A63688)
Case Titan 3530...
CHEVROLET C-60 GRAIN TRUCK (A63291)
CHEVROLET C-60...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
