Snow Mounting snow plow L series w loader
   / Mounting snow plow L series w loader #1
jodije
kubota L2900
I have a L 2900 with a loader and would like to mount a 6 or 7ft snow blade.Has anyone have expierence with this and can I mount the blade on/in the loader bucket or should the bucket come off and mount the plow on the arms.I intend on using the tractor hyd system to operate the plow. Tks John
   / Mounting snow plow L series w loader #2
The side load that the plow will put on the loader arms is not good... The farther out (like in front of the bucket) the worse it is going to be...
You would be better off removing the loader and mounting to the tractor frame.
   / Mounting snow plow L series w loader #3
This is my set up on my B series...with a 6.5 foot plow...
Originally manual angle, then added hydraulics. Works great.
Like Kenny said about force on the loader arms, I keep the plow straight and only use the angle with clean up / light stuff....
I also got rid of the chain, and installed a stiffarm, and place loader in float, so loader and plow float as one... (with the chain, the plow would ride up and the bucket filled with snow)
   / Mounting snow plow L series w loader #4
On my L2800HST I did one pin setup for 7'2" plow..pull the pin for bucket use,also if you have to use bucket to curl from getting stuck you can.
Plate bolted to bucket also re enforce back of bucket with 3/8"x 3".
Front plate frame welded sides high enough for plow frame support.
   / Mounting snow plow L series w loader #5
I like it! Any angle?
   / Mounting snow plow L series w loader #6
Firefighter Kubota.
45 degrees either way by hand.
   / Mounting snow plow L series w loader #7
Here is the plow I rigged up for my L3300. I bought an old truck plow for $150 and made brackets to bolt onto the tractor. I use the electro hydraulics that came with the plow. Easy, simple, foolproof and low cost.
   / Mounting snow plow L series w loader #8
Works great on a 5030
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
