kubota L235dt Hydraulic issue
   / kubota L235dt Hydraulic issue
Its to bad there is not a good place on this tractor to leave the gauge plumbed in all the time.
   / kubota L235dt Hydraulic issue #32
Why not plumb it in at the input to the FEL valve. You can then observe it when working, or add it to the dash with a rear hose hook up.
The first one uses a QD to connect at different points on the tractor.
The second one can be connected out of the way but available.
https://www.surpluscenter.com/item.asp?item=21-1044& catname=hydraulic
HYDRAULIC LIQUID FILLED GAUGE 0-6000PSI BOTTOM MOUNT - on eBay!
installing it at the loader valve might work - I will need to weld up a cover for it. I take this tractor in the woods a lot to drag trees out for firewood - I would be afraid of hitting it on something.
Its a great idea and it would give me a heads up if anything was going wrong with the pump
I received the PB plug today and after some running around to get the right metric fitting I installed the PB line and new return line to sump.
I have much more response out of the loader now and some more power. I talked with the tech at the hydraulic shop and he said that I was more then likely generating a lot of heat the way it was run before and that was why my loader and 3 point got weak after running it for a while.
I need some more seat time but my first impression is that it is better !
   / kubota L235dt Hydraulic issue #35
Great news:thumbsup:
2013 Ford Taurus Sedan (A50324)
2013 Ford Taurus...
BULLDOZER ROOT RAKE (A51243)
BULLDOZER ROOT...
RIGID TOOLBOX (A52472)
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
