hydralics 5210
/ hydralics 5210 #1
lbama
jd5210
Have a jd5210 1999 . Change hyd. fluid , filter and cleaned sgreen . After runnibg for 45 min to an hour the lifts become slow , steering jujmps , brekes only work if you pump them up . Need help please and suggestions?
/ hydralics 5210 #2
Welcome to TBN:D
After it's running, check and see if the fluid is foaming. Your symptoms sound like the system is sucking air on the return side, this can often be cause by the filter or screen that is not installed properly. You won't see a leak because there is negative pressure in the return line while the tractor is running.
/ hydralics 5210
Have a jd5210 1999 . Change hyd. fluid , filter and cleaned screen . After runnibg for 45 min to an hour the lifts become slow , steering jujmps , brakes only work if you pump them up . Need help please and suggestions?
Also fluid gets very hot , steamy , fluid feels like it break downs
/ hydralics 5210 #4
OK, there is a blockage I would guess. Do as I stated above and check the filter and screen again.
/ hydralics 5210 #5
Just to clearify what kennyd posted, I am sure he meant that air is getting sucked in on the suction side of pump....that could happen if suction line is restricted, or suction strainer clogged, a poor hose clamp or hole in the hose....
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2018 Ford Escape SE SUV (A64557)
2018 Ford Escape...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
International 470 Disk Harrow (A66408)
International 470...
2008 JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
2008 JOHN DEERE...
2018 KAWASAKI 4010 SPECIAL EDITION MULE (A65054)
2018 KAWASAKI 4010...
