Securing Backhoe to trailer question
/ Securing Backhoe to trailer question #1
allthingsoutdoors
Kubota L3240
I have been reading the DOT requirements to secure a backhoe to a trailer. It requires 2 chains/boomers on the front and 2 chains/boomers on the rear of the backhoe/tractor. The backhoe bucket has to be lowered to trailer deck and also chained down.
My kubota BH90 backhoe(on my L3240 HST tractor) has 2 1" diameter transit pins. One goes in to keep the boom centered so it can't move left or right. The other goes thru the boom when it is raised all the way up to keep it from moving or sagging down. The Kubota manual recommend to put the pins in when the tractor is in transit. (Maybe they mean when I am driving the tractor)
The problem is I can't lower the boom to chain the bucket down with the pin in. Should I forget about the boom pin and just lower it down and chain down the bucket?
I have been using the 4 chains/boomers on the tractor but just putting in the 2 pins for the backhoe part. I have never been stopped but would like to know what is right.
/ Securing Backhoe to trailer question #2
I would lower it down and chain it. I really do not think you can go wrong either way but lowering it down and chaining it prevents stress on the rear of the tractor from the BH bouncing around when you hit bumps. It also makes the DOT guys happy.
Chris
/ Securing Backhoe to trailer question #3
Chris
I agree. Aside from the fact that DOT mandates the BH and loader are also secured, the bouncing of the backhoe arm puts tremendous stress on the tractor. I use ratchet straps on the loader and backhoe buckets. Put a nice thick board down under the BH bucket to protect the wood floor if that's what your trailer has.
/ Securing Backhoe to trailer question #4
Chris
I agree 100% with Chris on this one. When transporting a backhoe, lowering the boom also drasticaly reduces the risk of crashing into over head hazards such as bridges and wires. Every hoe I transport on the carryall ALWAYS has the boom lowered so the bucket is laying on the deck and a G70 rated chain and binder securing the boom.
/ Securing Backhoe to trailer question #5
you're close, but not for the right reasons.
1. equipment under 10,000lbs requires minimum TWO chains/straps, rated correctly for the weight.
2. equipment over 10,000lbs requires minimum four chains/straps rated correctly.
Your L3240 is way under 10,000lbs and thus only needs two for the tractor
Plus, any part that is not held in place mechanically (i.e. hydraulics won't do it), must be prevented from moving mechanically. some backhoes pin in place mechanically and that works. But it also means your LOADER must be prevented from moving. (front, one over the bucket and strapped down) and one over your backhoe/bucket.
those don't have to be very big, remember the weight rating is cumulative. If your equipment weighs 9000lbs and you need therefore 4500 and you use one 4000 rated chain, now you only need 500 more lbs of force. Now you are going to take crap over this approach but it is legal. I use similar sized (way overrated, but that's just me)chains on the tractor and then use really small chain for the backhoe/front loader. It's not holding the tractor to the trailer, it's keeping the loader/bucket from moving in any direction.
If you can manage to hold the tractor on while holding the loader bucket down, you can use one less. I secure my skid steer like that (over the bucket, thru the frame and then down. Tractor secured, bucket secured. 1 less chain)
Look up equipment under 10,000lbs in FMCSA rulebook, I think it's .111, .113 something like that.
/ Securing Backhoe to trailer question #6
The other reason for chaining down the buckets is to prevent them from jacking themselves upwards with each bounce if valves are not left open.
That then reduces the risk of bridge strikes.
/ Securing Backhoe to trailer question #7
From the statute - the applicable rules in full
government speak.
Vehicles, equipment and
machinery which is lighter than 4,536 kg (10,000
lbs) may also be secured in accordance with the
provisions of this section, with ァ393.128, or in
accordance with the provisions of ァァ393.100
through 393.114.
ァ393.110 What else do I have to do to determine the
minimum number of tiedowns?
(a) In addition to the requirements of ァ393.106, the
minimum number of tiedowns required to secure an
article or group of articles against movement
depends on the length of the article(s) being
secured, and the requirements of paragraphs (b)
and (c) of this section.
(b) When an article is not blocked or positioned to
prevent movement in the forward direction by a
headerboard, bulkhead, other cargo that is
positioned to prevent movement, or other
appropriate blocking devices, it must be secured by
at least:
(1) One tiedown for articles 5 feet (1.52 meters) or
less in length, and 1,100 lbs (500 kg) or less in
weight;
(2) Two tiedowns if the article is:
(i) 5 feet (1.52 meters) or less in length and
more than 1,100 lbs (500 kg) in weight; or
(ii) Longer than 5 feet (1.52 meters) but less
than or equal to 10 feet (3.04 meters) in
length, irrespective of the weight.
(3) Two tiedowns if the article is longer than 10 feet
(3.04 meters), and one additional tiedown for
every 10 feet (3.04 meters) of article length, or
fraction thereof, beyond the first 10 feet (3.04
meters) of length.
(c) If an individual article is required to be blocked,
braced or immobilized to prevent movement in the
forward direction by a headerboard, bulkhead, other
articles which are adequately secured or by an
appropriate blocking or immobilization method, it
must be secured by at least one tiedown for every
3.04 meters (10 feet) or article length, or fraction
thereof.
(d) Special rule for special purpose vehicles.
The rules in this section do not apply to a
vehicle transporting one or more articles of
cargo such as, but not limited to, machinery or
fabricated structural items (e.g., steel or concrete
beams, crane booms, girders, and trusses, etc.)
which, because of their design, size, shape, or
weight, must be fastened by special methods.
However, any article of cargo carried on that
vehicle must be securely and adequately
fastened to the vehicle.
ァ393.112 Must a tiedown be adjustable?
Each tiedown, or its associated connectors, or
its attachment mechanisms must be designed,
constructed, and maintained so the driver of an in-
transit commercial motor vehicle can tighten them.
However, this requirement does not apply to the use
of steel strapping.
ァ393.114 What are the requirements for front end
structures used as part of a cargo securement system?
(a) Applicability. The rules in this section are applicable
to commercial motor vehicles transporting articles
of cargo that are in contact with the front end
structure of the vehicle. The front end structure on
these cargo-carrying vehicles must meet the
performance requirements of this section.
(b) Height and width.
(1) The front end structure must extend either to a
height of 4 feet above the floor of the vehicle or
to a height at which it blocks forward movement
of any item of article of cargo being carried on
the vehicle, whichever is lower.
(2) The front end structure must have a width which
is at least equal to the width of the vehicle or
which blocks forward movement of any article of
cargo being transported on the vehicle,
whichever is narrower.
(c) Strength. The front end structure must be capable of
withstanding the following horizontal forward static
load:
(1) For a front end structure less than 6 feet in
height, a horizontal forward static load equal to
one-half (0.5) of the weight of the articles
of cargo being transported on the vehicle
uniformly distributed over the entire portion
of the front end structure that is within 4 feet
above the vehicle痴 floor or that is at or below a
height above the vehicle痴 floor at which it
blocks forward movement of any article of the
vehicle痴 cargo, whichever is less; or
(2) For a front end structure 6 feet in height
or higher, a horizontal forward static load equal
to four-tenths (0.4) of the weight of
the articles of cargo being transported on
the vehicle uniformly distributed over the entire
front end structure.
(d) Penetration resistance. The front end structure
must be designed, constructed, and maintained
so that it is capable of resisting penetration
by any article of cargo that contacts it when
the vehicle decelerates at a rate of 20 feet per
second, per second. The front end structure must
have no aperture large enough to permit any
article of cargo in contact with the structure to
pass through it.
(e) Substitute devices. The requirements of this
section may be met by the use of devices
performing the same functions as a front end
structure, if the devices are at least as strong as,
and provide protection against shifting articles
of cargo at least equal to, a front end structure
which conforms to those requirements.
/ Securing Backhoe to trailer question #8
Yup, bucket down and secured properly along with your chains. Your pins for "in transit" does mean when you are driving the machine as you figured. I'm yet to meet a friendly DOT cop. I think they all hate their jobs. With that being the case, I seriously doubt many would cut you any slack if they can find you in violation of any code or regulation. And, yes, as mentioned, your FEL also is supposed to be secured as well.
It sounds like a real pain, but I've gotten used to it and, to be perfectly honest, have learned to appreciate knowing my load is secure when some bozo pulls right out in front of me or cuts me off. When I've had truck and trailer brakes sliding to avoid an inattentive elderly driver who neglected to obey a stop sign I liked seeing that nothing on my trailer moved.
/ Securing Backhoe to trailer question #9
From the regs:
"ァ393.130 What are the rules for securing heavy vehicles, equipment and machinery?
*Question 1: If an item of construction equipment which weighs less than 4,536 kg (10,000 lb.) is transported on a flatbed or drop-deck trailer, must the accessory equipment be lowered to the deck of the trailer?
Guidance: No. However, the accessory equipment must be properly secured using locking pins or similar devices in order to prevent either the accessory equipment or the item of construction equipment itself from shifting during transport.
*Question 2: How should I secure the accessories for an item of construction equipment which weighs 4,536 kg (10,000 lb.) or more, if the accessory devices would extend beyond the width of the trailer if they are lowered to the deck for transport?
Guidance: The accessory devices (plows, trencher bars, and the like) may be transported in a raised position, provided they are designed to be transported in that manner. However, the accessory equipment must be locked in place for transport to ensure that neither the accessories nor the equipment itself shifts during transport.
*Question 3: A tractor loader-backhoe weighing over 10,000 pounds is being transported on a trailer. The loader and backhoe accessories are each equipped with locking devices or mechanisms that prevent them from moving up and down and from side-to-side while the construction equipment is being transported on the trailer. Must these accessories also be secured to the trailer with chains?
Guidance: No. However, if the construction equipment does not have a means of preventing the loader bucket, backhoe, or similar accessories from moving while it is being transported on the trailer, then a chain would be required to secure those accessories to the trailer."
Thanks for the information. I had not even thought about chaining down the front bucket. I am going to have to pick up 2 more chains and 2 more binders.
I live in TN where we have more rednecks per square mile than anywhere on earth(except possibly Kentucky) You would not believe some of the tie down jobs I have seen. 5000 pound tractors tied down with 2 ATV sized ratchet straps. I have seen one idiot in town who pulls his tractor around on the the the trailer with just the parking brake set.
/ Securing Backhoe to trailer question #11
For those of us that drive for a living, it is becoming a real problem. The law taking effect (2010) in November really makes it rough to be a driver, because it makes the driver responsible for everything, and makes stuff our responsibility that is out of our control, and even if we find it, we are not legally allowed to fix it (who wants a bunch of truck drivers adjusting brakes, fixing electrical problems, etc) so it puts us between a rock and a hard place. Perfect example was a stop in middle Georgia this week for a full blow inspection, where the inspector found a total of three things wrong. No serious problems like brakes, tires, etc, but I still got nailed for one of my hoses just touching the catwalk, a minor crack in the muffler (Penske's reponsibility), but I still get the points and a light out over my windshield (anyone want to see the picture taken as soon as I was told a light was out which shows all lights working? that I sent via email to my boss). These offenses are each given points and when the law becomes effective, will be retroactive for two years (or was it three?) Florida D.O.T advised us in a safety meeting that Georgia was in a "will write" mode and if you are stopped, they will write you up for something. For people who have watched this business go downhill for the last 30 years, have no points on my drivers license, one chargeable accident that ended up "not being my fault in court" and somewhere just over two and a half MILLION miles of what I consider safe driving, it concerns me that I will be fired from my job due to "safety violations" such as these.
The people controling my destiny don't have a clue what it takes to move freight in this country, and how the trucking business works.
Also, old folks aren't the only people running stop signs....
Thanks for listening to my rant...
David from jax
/ Securing Backhoe to trailer question #12
David,
That stinks. Sounds like drivers will have to do a tight safety inspection before taking out a truck and will have to refuse to go out if there are defects. I would assume that if you were fired over it, you would win a law suit as they were trying to force you to use an unsafe vehicle. Any defect that will result in your getting a ticket makes the vehicle unsafe.
Just my opinion --
/ Securing Backhoe to trailer question #13
David from jax
Not to mention weather, bad drivers, little ******'s, etc., etc. All of that and 35 cents a mile.
/ Securing Backhoe to trailer question #14
David from jax
Please show us exactly where I said it is only old people running stop signs. The fact is, I didn't. However, I will state that, in general, it's the younger and older drivers who are the worst. Which end of the spectrum takes the cake, I don't know.
I also made it clear that I've yet to meet a DOT law enforcement officer who has cut me any slack for anything. It seems like they will take all day, if need be, to find something that is in some sort of violation. You seem to be 'ranting' at my post yet it doesn't seem like you've experienced much different with the DOT cops.
/ Securing Backhoe to trailer question #15
In some states Dargo, if they stop, they have to write. You just have to hope that they don't decide you're their target for the day.
/ Securing Backhoe to trailer question #16
LOL, I'm always the target! I think I would get a citation for one tire having 2 pounds less air in it than the others. :eek:
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
Roller (A61572)
Roller (A61572)
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
