Sickle Bar Gaspardo FBR 3 pt sickle bar mower needed
   / Gaspardo FBR 3 pt sickle bar mower needed #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I 'm thinking about buying a new FBR Gaspardo 3 pt. sickle bar mower. Would like some owner feed back about it. I need to mow property lines, under evergreen trees, along creek bank, along road ways. I use a JD I-match quick hitch on my tractors. It appears that Dealers don't stock these mowers.
I live in North west Ohio and I would like to see one, before I buy.
Klink
   / Gaspardo FBR 3 pt sickle bar mower needed #2
While I can't help with your request as posted, I do own a G&S Superior 394-7 (also Italian) sickle bar mower that I bought from Carter & Carter Machinery in Johnson City, TN almost three years ago. It looks VERY similar to the Gaspardo, with two exceptions: a) the Gaspardo literature says the tooth guard bar is bolted rather than riveted which would be some easier to repair and b) it seems to cost a lot more ($3,615 vs $2,500).
I hay about 24 acres twice a year with mine, plus 1,000' of roadside and under trees. I have no problems that I would blame on the mower -- it operates as advertised from 90 degrees up to 60 degrees down without complaint. I've broken a few sections -- finding stray items like tow chains and it has been easy to repair -- mine came with a full replacement blade set that replaces as a unit. Re-riviting new sections is not difficult so I always have one replacement set ready to go. I did not get hydraulic folding, but if I was doing mostly roadsides it would be worth the extra dollars. Mowing acreage it isn't a problem to manual fold.
If you want to talk further send me a private message.
Any and all info always helps
Thanks VistanTn
Thanks Paul
I called them today and found out where they are located.
Between Marysville and Columbus Ohio on old route 33. About 70 miles from me. They said I could look at the mowers, but I have to buy off a local dealer.
Klink
   / Gaspardo FBR 3 pt sickle bar mower needed #7
Klink
We sell the 7 ft. Superior with hydraulic cyl for $3695 + approx $125 shipping to a business address in Ohio. We also have the same mower with no cylinder for $3450. Superior is a lot easier to get parts for. We sell both brands. Ken Sweet
   / Gaspardo FBR 3 pt sickle bar mower needed #8
Ken is that a dual/double action sickle mower?
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
John Dozer JD650 (A51691)
John Dozer JD650...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
