Sickle Bar Gaspardo FBR 3 pt sickle bar mower needed
   / Gaspardo FBR 3 pt sickle bar mower needed #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I 'm thinking about buying a new FBR Gaspardo 3 pt. sickle bar mower. Would like some owner feed back about it. I need to mow property lines, under evergreen trees, along creek bank, along road ways. I use a JD I-match quick hitch on my tractors. It appears that Dealers don't stock these mowers.
I live in North west Ohio and I would like to see one, before I buy.
Klink
   / Gaspardo FBR 3 pt sickle bar mower needed #2
While I can't help with your request as posted, I do own a G&S Superior 394-7 (also Italian) sickle bar mower that I bought from Carter & Carter Machinery in Johnson City, TN almost three years ago. It looks VERY similar to the Gaspardo, with two exceptions: a) the Gaspardo literature says the tooth guard bar is bolted rather than riveted which would be some easier to repair and b) it seems to cost a lot more ($3,615 vs $2,500).
I hay about 24 acres twice a year with mine, plus 1,000' of roadside and under trees. I have no problems that I would blame on the mower -- it operates as advertised from 90 degrees up to 60 degrees down without complaint. I've broken a few sections -- finding stray items like tow chains and it has been easy to repair -- mine came with a full replacement blade set that replaces as a unit. Re-riviting new sections is not difficult so I always have one replacement set ready to go. I did not get hydraulic folding, but if I was doing mostly roadsides it would be worth the extra dollars. Mowing acreage it isn't a problem to manual fold.
If you want to talk further send me a private message.
Any and all info always helps
Thanks VistanTn
Thanks Paul
I called them today and found out where they are located.
Between Marysville and Columbus Ohio on old route 33. About 70 miles from me. They said I could look at the mowers, but I have to buy off a local dealer.
Klink
   / Gaspardo FBR 3 pt sickle bar mower needed #7
Klink
We sell the 7 ft. Superior with hydraulic cyl for $3695 + approx $125 shipping to a business address in Ohio. We also have the same mower with no cylinder for $3450. Superior is a lot easier to get parts for. We sell both brands. Ken Sweet
   / Gaspardo FBR 3 pt sickle bar mower needed #8
Ken is that a dual/double action sickle mower?
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2010 BIG TEX 16 T/A TRASH TRAILER (A55745)
2010 BIG TEX 16...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
