Finally built 3 pt brush rake
/ Finally built 3 pt brush rake #1
Peej
Augusta GA
New Holland TC 35(primary), MF 165, JD 40T,
I started thinking on this about a year ago. Something to drag brush and pulpwood leftovers from hunting lease. Also a pretty good ripper tool.
Drew up a design and got with my buddy Jim at All American Equipment and this is what came from it,. I call it the Beast. Reinforced every where we could think. Don't think my TC 35 will tear it apart. Seatbelt a must when working around roots and stumps. Trash doesn't get up on rear tires like on my BB. 66" wide w/16" rippers. Threw in the receiver hitch for extra's, you just never know.
/ Finally built 3 pt brush rake #4
Now if you just had a little drop down support foot for the front, you could use those concrete blocks for something else.
/ Finally built 3 pt brush rake #5
Very nice work!
Thanks Guys, and working on the parking leg this week.
/ Finally built 3 pt brush rake #9
Do keep your foot near the clutch and one eye on the rippers for snagging you to a stop resulting into a scary tractor wheel stand. I know.
Nickel I sure do! Had one of those moments the other day with my box blade and a sand ditch.. pucker factor 10.
I saw where sweets farm equip had something similar to this and called it a pasture renovator . I didn't even know I had one of those now.
/ Finally built 3 pt brush rake #11
I like that and with a hydraulic top link, adjustable depth. You could put that on a float circuit as well and with the extension away from the tractor not be affected too much with gouging. This is why I am in favor of routing remotes through a joystick that has this function built in. Then you can decide which cylinder you want to have on the float valve. For me it varies as to what I have on the 3PT. It might have some tillage applications as well!
/ Finally built 3 pt brush rake #12
I've thought of a similar idea to clear trails.. Currently no trails, trees about 8 feet tall fir. I thought of mounting it behind a j5 bombardier tractor, which would run over all the fir trees, hooking and raking them as the just starting to stand up behind the machine. There is also a lot of dead falls about 6 inches in diameter inside all the brush that fell over 25 years ago. It just has to be good enough to walk through. I need miles and miles and just cannot cut it all. I thought of flattening most of it. And as it dies walk through and cut here and there with a chainsaw. But a j5 is 115 hp, 4000 lbs
/ Finally built 3 pt brush rake #13
Though that brings up the fact that I'd have to get a three point hitch to mount on the back of the j5. No hydraulics either, but I'm sure a small hydro pack would work enough for that
