gear ratio help please
/ gear ratio help please #1
gochenour799
Member
I need help calculating a reducing gear ratio. Example.. I have a gasoline motor I want to run @ 2000 rpms and a pump that needs to be run a 1250 rpms so I need to reduce the out put by putting a small gear on the motor and a larger gear on the pump , with chain in-between them . I can't figure out how to figure the size of the gears . Say 10 teeth and 20 would that be 50% reduction ?
/ gear ratio help please #2
2000 divide by 16 times by 10 = 1250.
So you'd need sprockets of 10 and 16 teeth for the motor and pump respectively.
Wow that was fast ..... THANK YOU so much for the reply..
/ gear ratio help please #4
1250 divide by 2000 = .625
10 divide by .625 = 16
/ gear ratio help please #5
A 10 tooth pinion is kinda racy. Try a 20 tooth pinion & 32 tooth gear.
/ gear ratio help please #6
or a 15 and 24 :D
Ok thanks everybody... I think I will idle the motor down to 1950 rpms and run a 25 / 16 that will give me 1248 rpms on the pump .
.1950/25x16=1248 ... the reason is I already have these sprockets...and if I need more I can just bump the idle up on the motor .
LOOK! (A63111)
LOOK! (A63111)
REDDICK 3PT SPRAYER (A64278)
REDDICK 3PT...
MF GC2300 fel replaced
MACH Rescue Tools with Power Unit (A64553)
MACH Rescue Tools...
1993 Chevrolet Corvette Coupe (A64557)
1993 Chevrolet...
2022 EZ-GO ELITE...
