GT275 Deck
/ GT275 Deck #1
tld
Boston, GA
JD 2025r
In addition to the plastic hood cracking I now see that the deck has holes in it several places. Seems the holes are in the area where the outer edge/end of the blade would be. Is this from normal rust or could it be something else?
/ GT275 Deck #2
Which deck do you have? Is it the 48C?
The hoods are rediculously expensive and rediculously fragile.
/ GT275 Deck
Yes, 48C.
Upper and lower hood is about 400 dollars. I keep looking for a used mower for parts, but they're all cracked too. The slightest bump and there goes 400 dollars. I do like the mower otherwise.
/ GT275 Deck #4
I had a GT242 for three years that I bought used. I beat the tar out of that thing. Including nailing the porch and a tree head-on a few times while learning it. Never so much as scratched the hood. :confused:
/ GT275 Deck #5
Did you GT242 have a metal hood?
His GT275 and my LX279 have plastic hoods. They are rediculously fragile.
/ GT275 Deck #6
The GT242 is the little brother of the GT275. GT242, GT262, GT275. Same tractor, different engines and decks.
/ GT275 Deck #7
I have a GT 235 and the hoods are easy to break (at least for me). The hood can be repaired. I have fixed mine twice. I used two part plastic glue and scrap pieces of plastic on the under side of the hood. The key is to rough up the surface to be repaired. I used an angle grinder. Looks good enough for a lawn mower.
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
John Deere 772CH (A64126)
John Deere 772CH...
2014 Mercedes-Benz GL 450 4MATIC AWD SUV (A61574)
2014 Mercedes-Benz...
KMC 7406 (A64126)
KMC 7406 (A64126)
Gradall no crank no start (A61568)
Gradall no crank...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
