Wood Chipper
/ Wood Chipper
I went through the threads about chippers. Some say chip green, some say let the stuff dry, some say it is dangerous, some say Jimna is great, some say Wallenstein is great, some say you need an automatic feed, some say you don't.
You know what, screw the chipper, I'll continue burying the stuff.
/ Wood Chipper #8
I just picked up a brand new Wallenstein BX62r with hydraulic feed. $5900.00 Cdn. plus HST tax. Not interested in a cheap chinese piece of junk that breaks the first time I use it.
This one is built by local mennonites in Ontario and looks extremely robust with top notch welds. Amazing considering the people who make them don't have electricity. :D
Got one in JD green. A flow control valve varies the speed of the feed drums.
BX42r/BX62r Wood Chippers - Wallenstein
/ Wood Chipper #9
I have the same or very similar chipper, mine is a Jinma version. looks virtually identical. I paid a couple hundred more about 5 years ago. Works pretty well. Does the job. I have had to do some repairs such as a belt and an internal shaft for the feeder. They have since improved this design and I used the updated parts. I also have reversed or replaced the blades, not too difficult. Overall very happy. I live in a very heavily wooded area with 5 acres, neighbors also have large wooded parcels. We have made allot of use of it. Definitely better then a home owner version & fairly heavy duty, but I would not rate for constant commercial operation. Documentation that came with mine was not very good and hopefully has improved. Parts are easily accessible. Price is very good and I think you could be very happy. Attached picture is of my wife showing off tractor and chipper.
/ Wood Chipper
Wow, that is a big chipper seen on the back of a BX. I was thinking of running a chipper on the back of my L3700, but you think it would be ok on the back of my BX-1850? At 1600 bucks and free shipping and if it performs as you say, I might go ahead and try it. It's just for my property and not commercial work. I don't necessarily want to keep Amish Canadians employed at 5K a pop.
/ Wood Chipper #11
Wow, that is a big chipper seen on the back of a BX. I was thinking of running a chipper on the back of my L3700, but you think it would be OK on the back of my BX-1850? At 1600 bucks and free shipping and if it performs as you say, I might go ahead and try it. It's just for my property and not commercial work. I don't necessarily want to keep Amish Canadians employed at 5K a pop.
The Bx1860 might be a little underpowered, but you also don't have to max out at 6" on that on either and will probably do many jobs. Chipper is heavy but the TPH will lift it. I always have my loader on when I use my chipper, besides where else do you put the saws and cooler? $5K was way too steep for me as I already put good money into a orange tractor. I am really pro North American made where possible, but on this one and level of use I intended, I decided to go this way. Another factor was the ability to broadcast the chips overhead and back into the woods was a plus that I was having difficulty finding at the time. I was just out in the shop and saw the date on the unit and I have had it over 5 years. Very satisfied- No regrets, and I have chipped way beyond my initial expectations, pushing it quite a few times doing Storm damage clearing over the past couple of years.
I have used this on a 22hp BX and now my 25.5hp BX. Worked well on both chipping up to 6". Definitely noticed the additional power of the newer tractor though. Now on the other hand this thing should be a monster on your L3700!
/ Wood Chipper
Thanks Tim. I appreciate it. As you may have noticed others that haven't used the product implied it was junk. $1,600 compared to $5,000 is a big difference.
/ Wood Chipper #13
If you have a Tractor Supply Company (TSC) by your place, you can look at the same chipper and it will cost more than the price you are looking at.
/ Wood Chipper #14
I studied long and hard before buying the Jinma. One point, is be sure it is a Jinma. The only thing worse than a Chinese tool, is a knockoff of a Chinese tool. I have had mine many years, doing just what you say you will do. I made all the improvements on the list. Most I figured out before I read about them. I am totally happy with mine , FOR THE PRICE. It is way below perfect. If you run it yourself and don't loan it to some cowboy, you Probably will be as happy as I am. If you aren't a mechanic, don't even start this project. Even with the upgrades they have made since I got mine, they take tinkering and keeping everything adjusted.
/ Wood Chipper #15
Ha! ha! me neither! 5K a pop! send that Canadian to the un-employed line. 1600 bux is very good price for a Wood though.
/ Wood Chipper #18
Bearcat, Woods, Wallenstein, Goosen...for a bit more money, Valby.
I've got a Woods (my particular model is made by Bearcat, sold by Woods). Great chipper!!
/ Wood Chipper #20
do you have trouble with it clogging? chute clogging?
This model, the 5000, doesn't have a chute. The chips fall below the chipper. There is a kit to add a blower/chute, but for the amount of chipping I do, I can rake out the chips (to a pile) and move them to another location with the loader.
Although the input chute looks awkward to use, it's not and it well suited for 5" material. I've fed smaller trees (5" trunk by 30-35 foot length) with no problems. The shredder (top opening) is good for material up to an inch in diameter as well as brush.
Freshly cut stuff chips OK, but I've found letting the material set for a few days to dry out results in easier chipping.
I bought this off CL for $1000. New cost as shown in the picture is a bit under $3000. For a homeowner with a few acres of trees or a small farm, the Woods (Bearcat) is a nice chipper. You'll want 20 PTO HP minimum to run it. Woods also puts a maximum of 30 PTO HP, but the Bearcat version (same machine) is rated to 40 HP.
BTW, if price was no object, I'd go for a Valby...but for my purposes, this Woods does a great job!!
