Fire Wood Storage Shed
/ Fire Wood Storage Shed #3
Several years ago I built a classic pole shed with gable roof. Used sawmill lumber on everything except poles (6X6 treated). Shed is 14X28. Open on one side, 1X6 vertical on other three sides - with space between boards to let air circulate. Stacking 6' high, I can, in theory, store 19.68 cords. My outdoor wood fired boiler sticks out of one end so that the loading door is under cover. In reality, I probably stack closer to 12 cords at a time. It works great for our purposes.
Mike
/ Fire Wood Storage Shed #5
I stack most of mine along the back side of a metal carport out back, on pallets, covered with plastic tarps through the Fall & Winter. I usually have my wood cut by the first of the year to use the next Winter. Stack it (unsplit) at the farm until I have room at home. ~~ grnspot110
/ Fire Wood Storage Shed #8
How big are you looking for? I built a 8x12 that holds 3 cord of wood although I don't put that much in it. It's dark out so I couldn't get pictures of the back but the top 2 feet are also open to allow air flow.
/ Fire Wood Storage Shed #9
If the unit is just for wood storage, plenty of ventilation. Air movement is good thing. hearth.com is a great site
/ Fire Wood Storage Shed #10
I will have some pics of what I'm doing soon. I'm stacking my wood on pallets and then putting a few at a time inside my garage, when i need the wood. The wood will stay outside uncovered until needed. Sometime in early Nov i will move enough in for most of the winter.
/ Fire Wood Storage Shed #11
Here are some pics of my wood shed. Its 8' x 40'. I probably have about $800 invested in materials and most of that was the steel.
/ Fire Wood Storage Shed #12
Looks good, I need to build something like that too. How deep did you dig the post holes? Or are they sitting on the ground?
/ Fire Wood Storage Shed #13
Technically they should be buried below the frost line. In truth, I was using posts I already had so to keep the height I wanted I could only bury them 24 inches. Doesnt seem to be a problem. I get no heave in the winter.
