Mowing 48" Finish Mower Blade challenge
/ 48" Finish Mower Blade challenge
Easy way to verify all blades have the same rotation would be to lift the deck all the way up, turn off the tractor and move an outside blade by hand ensure the others move in the same direction.
Did both - watched it turning from a safe distance and then did your suggestion. Good thing I did not blend the two together otherwise I would be typing this with my nose. :D Thanks, Jim --
I've attached a pic of the belt rounting on the 60" mower deck -- I don't know if the 48" is the same. As Moss described, the center arbor is driven by the hydraulic motor.
Kent, Thanks for the pics and the suggestions. Much appreciated. Jim --
/ 48" Finish Mower Blade challenge #23
As I recall, isn't the center blade held on just a little differently than the outer blades? I recall retainers, or devices to keep the outer blades from being able to spin on their mounts while the center blade was just a flat washer. I think it was because the center blade is affixed directly to the motor that there was no retainer so if you hit something solid, the center blade could possibly spin on its shaft instead of damaging the motor. I'm going to have a look at my deck the next time I mow, which may not be a while because we have had no measurable rain in a loooong time. :(
/ 48" Finish Mower Blade challenge #24
I don't think anyone else suggested this, but before starting the blades, I take the engine down to a fast idle. This reduces the start up stresses on bolts, belts, and pulleys. Too low a fast idle and the engine will stall. You may have to play with this.
/ 48" Finish Mower Blade challenge #25
I do the same thing...
/ 48" Finish Mower Blade challenge #26
I do this also. :thumbsup: I think this is especially important when using the brush mower since the blades kick back against the stop bolts, but most likely good for the finish mower too.
/ 48" Finish Mower Blade challenge #27
Make me #4 for the slow engine RPMS at mower or brush hog startup.
/ 48" Finish Mower Blade challenge #28
Always. I try not to shock mechanical components, and it seemed like the right thing to do.
All the best,
Peter
All the best,
Peter
Guys,
You all continue to make great suggestions.
Quick Update: I am checked the areas from your suggestions, and I used the blue permatex on the new grade 8 bolt, and am starting at low rev. I just cut a little over an acre and it held fine. Hopefully, it will continue to hold. Thanks for all of the great ideas.:thumbsup: Awesome forum!
Jim
Yes. Your recollection is correct. I spoke to Terry about it, and he was surprised that it had happened. He was not aware of the problem on another unit. I think I or the previous owner must have hit something to cause the weakness. Anyway...it is holding for now. I am going to play it cool like Luke and see if it continues to hold. :cool:
By the way...talking about the weather, my electric bill from Philadelphia Electric shows the average daily temperature for July at 80 while one year ago it was 73. No wonder everything is frying without the rain. We had some recently and the ground is still dry. Is it the same everywhere else? Jim --
/ 48" Finish Mower Blade challenge #31
Yep. This is one of the top 10 driest Augusts in Indiana. I am pulling dead leaves out of my pool already. Not supposed to do that until end of Sept.
Haven't mowed our lawn in 2-3 weeks. It just isn't growing.
I will have to add water to my pool for the first time this season, too. It is down 2". Earlier in the year I had to pump it out 4 times due to all the rain.
White Oak Boards (A65640)
White Oak Boards...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
John Deere D110 Riding Mower (A62679)
John Deere D110...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2013 International WorkStar 7500 Side Loader Garbage Truck (A64194)
2013 International...
