Another Project
/ Another Project #1
JesseA
1940 Massey Harris 101 SR
Possibly as much of a Trial by Fire as a project I guess.
Interweb Massey Harris Serial Decoder Says its a 1940 MH 101 Sr.
Casting #s on the front frame hull says 11-25-40, So Im guessing that it was assembled in December of '40.
It came into the yard with a seized left brake assy, seized but floppy shifter, seized steering gearbox, and 5 gallons of water where there should have only been gear grease. Freed up and greased up everything that would take it and dissasembled, heated and beat on stuff that wouldnt take lube, until it would.
This is my first foray into the world of Tractors, But inspecting the Transmission, it appeared to be in excellent shape. I was unable to get the top link/diff cover off to look in there, but I expect its in the same kind of condition.
Probably over the last 50 years or so, It slowly lost its tin, tank, and everything else that was attached to the Engine. Im unsure about what to power it with, but Unless a Continental or Chrysler engine that belongs in one shows up cheap and easy, its probably going to get something automotive like a GM250-6 or AMC258-6 or small industrial Deisel- Thinking an F3L-912 or a 2-53 Detroit.
But anything could happen.
/ Another Project #2
Good heavens, that's a bit hurting. Well, at least the rear tires match!!!
/ Another Project #3
And I thought I had my work cut out for me !! :D . Good luck with it and you're in the right place for advice and ideas! Take lots of pictures and keep us posted on the progress. :thumbsup:
/ Another Project
Scary enough is that they appear to hold air for at least 24 hours too!
White 6182 12R Planter (A66285)
White 6182 12R...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
5' Dearborn Disc (A62613)
5' Dearborn Disc...
31" Minin Excavator Bucket (A66285)
31" Minin...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
