Loader Settling
/ Loader Settling #21
If one has a manual hyd pump, with gage, and connected it to a cyl, he could pump up the pressure to the tractor psi, and determine if the cyl was leaking. If the pressure bleeds down, then the fluid is bypassing. Then check the other cyl port to see if bypassing in the other direction.
This is how I test WPR's on control valves off the machine.....it also show's the integrity of the spool tolerances....:thumbsup:
/ Loader Settling #22
How do you make sure the leakage is not in the hand pump??
/ Loader Settling #23
Using 10,000 psi Hand pumps (Enerpac, OTC, Simplex ect.) gives lots of adaptability....We use High Pressure Tee's w/ 10,000 psi guage, 6' hose and 10,000 psi rated QC's....easy to check the integrity of the hand pump by disconnecting Quick Coupler and deadheading pressure against it.....
(5) Round Cornstalk Bales (A66408)
(5) Round...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
Woods Cadet MD172 Pull Type Mower (A66408)
Woods Cadet MD172...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
TRIP HOPPER JR CUBE / CAKE FEEDER (A64278)
TRIP HOPPER JR...
