Tower crane op
/ Tower crane op #1
Keller
Member
Hello I'm a heavy equipment operator that specializes in tower cranes. I been lurking hear for a few years and just now needed to register lol. You can usually find me in the build it yourself forum or the projects.
/ Tower crane op
Don't know if any one will care but there is my rig. Pic taken from the otter tower on a nice foggy morning.
/ Tower crane op
My view
/ Tower crane op #4
I have been manufacturing and servicing truck cranes for years. I made product for Manitowoc and Manitex. Do you use there products?
/ Tower crane op #5
So how many steps to get up to your "office"... (...and can I go for a ride out on the end of the crane?) :D:laughing::thumbsup:
/ Tower crane op
Yes MD3 I ran a lot of "pickers" before they let me run the big stuff. And I was broke in on a Manitowoc 4100 ringer.
/ Tower crane op
It's about 180'. Yep there's a little service basket that hangs off the trolly you can ride. Don't worry I'll go slow. :D
/ Tower crane op
Hey how do I put a pic next to my name?
/ Tower crane op #9
Look at the second line at the top where you see "Main Index", "Today's Posts".... Click on the "My Home" tab...
On the left side look for "Settings & Options" and the first one you want is "Edit Avatar"... then you have two options... if you need any more help, just ask...
/ Tower crane op
Well I'm using the iPhone app. I'll have to do it on the comp
/ Tower crane op #11
Question for you: When lifting a load, do you move the counter-weight
at the same time to keep everything balanced?
In Germany, they use small versions of these cranes for relatively small
residential building projects, believe-it-or-not. Usually they are "planted"
in the back yard and kept there until all the major materials are installed
for a new house.
/ Tower crane op
for a new house.
No. Their is alot of deflection built in to the crane. The tip probably drops 10 feet at max load.
I have run a crane that did that once. They called it a kangaroo crane. And the counter weights extended out at the same time as you boomed down. Pretty neat. But it was still run like a conventional crane. I like the tower much better
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
AGT SDA-140T (A64912)
2022 BOBCAT T870 SKID STEER (A65056)
2022 BOBCAT T870...
John Deere HPX 4x4 Gator (A64912)
John Deere HPX 4x4...
(INOP) 2005 CATERPILLAR 535B SKIDDER (A65056)
(INOP) 2005...
2023 Landmaster (A64912)
2023 Landmaster...
