hydraulic pressure
/ hydraulic pressure #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i know i have read this on here somewhere. i did a search but i could not find anything,, i may just dont know what i am doing... anyone know how to turn up the hydraulic pressure on a massy ferguson 1540..? and should i check the pressure before and after ?? and where is the best place to do this ... sorry for all the questions,, i must be getting old ,,i cant remember---- well you know ,,,thanks for any help bruce
/ hydraulic pressure #2
try to locate the pump and the outlet port....check for "plug" or QC fitting connected to outlet port.....
/ hydraulic pressure #3
You MUST check the pressure before and after, you must also know what the recommended pressure is so you do not exceed it. I don't know where the main PRV (pressure relief valve) is on your machine, but that is what you need to find.
Why do you want to raise the pressure? Doing this wrong cause cause very expensive damage to your machine...
/ hydraulic pressure #4
You can tee a gage into the first valve after the pump. Find a manual to determine the manufacture rated pressure. If it is low, adjust it by using shims or turning a screw down to increase pressure.
/ hydraulic pressure #5
Check the loader control valve for the relief cartridge, front side pointing straight down closest to the frame casting. Adjust at your own risk, i.e. know what you're doing. Item 40 in the last attachment.
  • 03. Hydraulic Piping Illustration.pdf
  • 1540 Hyd Location.pdf
  • Relief Location.pdf
  • Relief Vlave.pdf
/ hydraulic pressure #6
before you run off adjusting reliefs.. what is your problem and or symptoms.
most of these ag systems are running 1500-2500 psi or somewhere inbetween depending on the year and manufacturer... and were set that way for a reason..
soundguy
/ hydraulic pressure #7
soundguy
Exactly. Turning the screw on a relief valve is not going to fix a worn out hydraulic pump or a bad cylinder packing.
Brian
/ hydraulic pressure #8
hernando,
Do you know what the pressure should be. It is easy enough to adjust, but like the others have said, should you. What do you hope to gain? Before and after what?
If your hyd system is not good and tight, you might never be able to set the relief.
thanks for all the help..i was hoping to be able to lift more weight...but after having my loader valve cleaned and checked it works better than ever....thanks for all the replys and help . bruce
Welcome to the Ranch (A64557)
Welcome to the...
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2022 SANY SY155U EXCAVATOR (A63276)
2022 SANY SY155U...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
