Lock washers don't work?
/ Lock washers don't work? #21
Yet another great educational discussion on TBY! I remember that back in the day that my dad was in the aviation business, beginning with piston engines and finishing with a fleet of DC-9s, there were no split lock washers. Inside toothed, more often deformed lock nuts, and when it had to stay tight, plain old SS safety wire. There was lots of safety wire used- I think I still have several spools of it I inherited. But, I don't fly in anything I have worked on, so it doesn't get much use. Sure, they sometimes used Lok tite, but never when it just couldn't fail. Funny, but I miss the sound of radial engines and the smells of engine shops.
Hahh,
As "Young adults" we cross drilled and safety wired EVERYTHING on motorcycles (primarily Norton thumpers) of the day.
I still miss the smell of Castrol R (-:
/ Lock washers don't work? #22
Another type of locking washer I found about recently is a Schnorr washer. These are serrated and we use them in pairs in certain applications. When torqued (when used in pairs), it takes more torque to break them loose.
/ Lock washers don't work? #23
That sounds to me like, what we buy as Nord-lock washers... they are the best mechanical system (apart from safety wire, but wiring is too time consuming to keep up with a modern assembly line ;) )
/ Lock washers don't work? #24
That sounds like the engine of my 3011 which i just got running again, after rebuild.. Its 1958 design is a textbook example of effective simplicity, but somehow it was treated as a NASA rocket: connecting rods are cross drilled and locked with split pins, oil pump and suction tube are locked with wire... I couldnt get the stuff anywhere, so i just used MIG wire instead... ;)
/ Lock washers don't work? #25
As long as it's stainless steel wire, you should be fine. .032"-.040" wire works really nicely.
For you guys who safety wire...if you buy the pliers, don't go nuts twisting the wire. Don't twist any tighter then you can do by hand. Weakens the wire (cold working).
/ Lock washers don't work? #27
Very interesting! However I never had a lock washered nut to go lose on me - as long as it is the german way - gutntit:thumbsup:
/ Lock washers don't work? #28
:thumbsup:Thats just correctly tightening the fastener. Yould get a more healthy joint using hi strength flat washers because they broaden the clamp point.
larry
/ Lock washers don't work? #29
... Just got me thinking... using MIG wire on a DC-9 ?? :p :p
No...safety wire is safety wire. In a high stress application (aerospace) in which loose fasteners can result in a catastrophy, I wouldn't suggest using anything but safety wire.
My first response was, to put it mildy, ill advised.
In Renze's application, that wire may hold up...might not. Guess using MIG wire was better then nothing though.
/ Lock washers don't work? #30
larry
I would think more surface = less PSI so the fastener wouldn't be as tight.
/ Lock washers don't work? #31
What you want is good clamping force .. a function of the correct torque of the fastener. Spreading the same force over a broader area doesnt affect the tightness of the bolt at all, and gives more uniform clamping. The smaller area does equate to more concentrated force [higher psi] .. same force over smaller area. This is very seldom a good thing for the clamped pieces.
larry
/ Lock washers don't work? #32
...:p i was just kidding about using MIG (a Russian cold war fighter jet) wire on a DC9 from the same era...
Sorry, dont know much about aviation, i just like word jokes :)
/ Lock washers don't work? #33
Now that I get it, that's FUNNY! There has to be a joke in there somewhere about using 6010 rod for MIG welding.
/ Lock washers don't work? #34
I suppose this post is a bit late, but whatever. I read a pretty good article a couple weeks ago about fasteners. It was written by the guy who runs Pirate 4x4, which is the hardcore off roading equivalent to Tractor ByNet. I thought the article was well worth the time it took to read, so I figured I'd post a link to it in case anyone was interested.
Pirate4x4.Com - Extreme Four Wheel Drive
/ Lock washers don't work? #35
I guess I'm frugal. I tend to take a simple grade 2 nut and turn it onto a bolt a couple of threads then hit the open side with a hammer slightly deforming the nut creating my own lock nuts. I have had great luck this way. :D
/ Lock washers don't work? #36
The threaded studs in the gearbox of my muck spreader are locked on the backside by hitting the thread with a center punch, axially to the thread. Any deformation will work.
/ Lock washers don't work? #37
Thanks for the post!
Bob
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter with PTO (A61166)
New/Unused...
Mini rock grapples (A61567)
Mini rock grapples...
17601CFL (A59228)
17601CFL (A59228)
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A62131)
UNUSED WOLVERINE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
