Loader Settling
/ Loader Settling #1
KuboB1200
Member
Folks,
I have a 1995 Kubota B2100 with an LA 301 loader that the loader has recently began to settle. The bucket is fine, but the loader cylinders settle and it's apparent with a load in the bucket. The loader will settle with the engine running and no load (nothing in the bucket) requiring that I reposition the loader every few minutes. It will also settle in the reverse, like when I lift the front wheels off the ground by lowering the loader all the way.
All other hydros work fine.
Any ideas on how I can troubleshoot to see if it's the cylinders or valve body?
Thanks,
Kubo
/ Loader Settling #2
Swap Bucket tilt lines with your Bucket lift lines.....if the problem doesn't change then your lift cyls need repacking......if your bucket tilt now creeps then you have DCV bypassing.....:thumbsup:
/ Loader Settling
Thanks,
Looks like it may be the DCV spool leaking since when I lift the front wheels off, it settles.
Kubo
/ Loader Settling #4
An internally leaking cylinder will get warm after time, especially if you run it to the end of the stroke and hold the lever for a few seconds. I would expect your problem to be cylinder seals rather than a valve problem.
Kim
/ Loader Settling #5
If the valve has work port relief, check them for trash. Is the lever returning to center, or sitting off of center.
/ Loader Settling #6
Kim
I use a $50 non-contact infrared thermometer to troubleshoot bad hydraulic cylinder piston seals. If the area where the piston is sitting shows me as little as 5 degrees more than the rest of the cylinder, it's leaking by. This method has been 100% effective for me over probably a dozen repairs.
/ Loader Settling #8
Thanks,
Kubo
Don't rule out piston seals....they'll creep/settle in both directions....swapping hoses is quick and painless to do without pulling anything apart yet....:)
/ Loader Settling #9
Try holding the lever to full extend, and full retract, and see if the PRV relief activates.
/ Loader Settling #10
Good way to trouble shoot. Good post.
/ Loader Settling #11
Good tip!
larry
/ Loader Settling
Great stuff, guys. Thanks for all of your suggestions. Here are some more tidbits.
The lever centers fine and everything works great. One thing I have noticed is that the bucket creeps down, as well. Both a little at a time while I use the tractor with engine running a 2000 RPM (mowing).
Yes, the bypass works fine after both lift and full down.
It's been doing this a while, now, but when I tip the bucket down (so the bottom is perpendicular to grade) and lower the loader to spread dirt while backing up (lightly), the bucket doesn't stay in position and curls back up. Like it's pretty loose. I have to reposition (tilt up) the bucket a smidge to get it to stay. I thought it just sucked some air past the seals last winter and was needing to work itself out. I have taken the loader and bucket through cycles to bypass.
Bucket holds and lifts fine, it's just the creep.
Kubo
/ Loader Settling
JJ,
I'm sorry, I don't know what a port relief is. From the schematic of the parts list, I see a "load, check" for each valve. Obviously, the valve has a bypass valve. I don't "hear" any oil flow while the bucket is being held.
The valve assembly is a Danfoss 1625 AN, made in the USA.
Just got back from the shop. When going to full dump, I have to hold the lever over about three seconds after maxing the cylinders out in order to hear the bypass engage and the motor lugs. After that, the bucket has no "free play" and holds its position.
With the bucket dumped all the way, I can lower the loader and lift the wheels off the ground. You can then watch the cylinders slowly settle and the wheels return to the ground.
After taking the loader and bucket cylinders to bypass and holding for 10 to 15 seconds, I notice no heat buildup in any cylinders.
Kubo
/ Loader Settling
Guys,
I can't tell if that relief valve is functioning. It sounds like the relief on the tractor is functioning (internally), and the valve body is getting warm and I can feel noticeable heat from hot oil at the relief valve.
It's the quietest BPV I've been around. I'm confused. I'd run it to the dealer, but it's 70 miles away.
Kubo
/ Loader Settling #15
Some valves have work port reliefs, and some don't.
/ Loader Settling #16
JJ,
Kubo
Are you measuring cylinder temperature definitively, or by 'feel'?
10 to 15 seconds probably isn't enough to build measurable heat in the piston & barrel. 75%/25% on/off cycles for a minute or more are required.
/ Loader Settling #17
Just a friendly note that you can not measure chrome or cad plated items with an IR gun, unless you can adjust the emissivity factor, which most cheap ones can't. The plating essentially reflects some of the IR energy back into the item giving you false lower temperature readings. Rubber and non-metallic paint are good. You can get around this problem by spraying a little paint on it or putting a piece of masking tape on it. (just give the tape a little time to warm up)
I am an engineer and ran into this problem on a production line. My friend calls IR guns "random number generators" :)
ISZ
/ Loader Settling #18
ISZ
It would take an engineer to discredit a troubleshooting technique used successfully in the field by many of us lowly service techs.
I'm not checking plated items, just the painted barrel which is consistent in color & texture. There is no need to take temps from the rod, and not too many cylinder barrels are plated on the outside. Values are compared, not taken as absolutes. My results using this methodology speak for themselves. Whether anyone else chooses to follow, I couldn't care less. The probability of the OP having a bad piston seal is considerably higher than that of a valve problem, IMHO.
/ Loader Settling #19
While I've never used this IR method to determine a piston seal leak, I tend to agree with RickB about piston rather than valve....But then that's me....;)
/ Loader Settling #20
If one has a manual hyd pump, with gage, and connected it to a cyl, he could pump up the pressure to the tractor psi, and determine if the cyl was leaking. If the pressure bleeds down, then the fluid is bypassing. Then check the other cyl port to see if bypassing in the other direction.
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A67147)
2005...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
