Box scraper add on
   / Box scraper add on #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
Folks,
I saw this in another thread...
http://www.tractorbynet.com/forums/...ew-box-blade-followed-me-box-blade-repair.jpg
I really like the way he did that ball mount...
now I have 5x8 utility trailer and often I need to move it around...
in the past I have just lifted it with the bucket and hooked the chains to the top lip and moved on...
Well in my last rush, I cut the wires and then it bent the hook on one of the chains...
But I admit it was totally my fault..
I was in a hurry and should not have done it..
so after seeing the thread pic above--
thanks John for the great idea!!
http://www.tractorbynet.com/forums/members/johninct.html
My options are this:
Pintle Hook with 2" Ball
or on the top lip of the box:
ATV Hitch Adapter
of course I understand the issues of weight behind the lift arms and all that.. but we are talking about a trailer that on flat ground I can pickup the tongue and roll by hand....
So what do you think about the pintle hook idea?
J
   / Box scraper add on #2
Folks,
ATV Hitch Adapter
J
the pintle hitch does sound like a good idea but if you can pick up the tongue by hand, why couldnt you just put a trailer ball on your draw bar? Unless you keep the boxblade on all the time, this may work a little better. Just IMO.
the boxblade is almost always on... well except for the winter.. and then the scrape...
problem is when I need to move it.. it is too far to move by hand....
J
   / Box scraper add on #4
J
well, if you use a pintle hitch, just take some box tubing, cut to length of end of hitch, and weld it to a plate of steel. Drill 4 holes in both the corners of the steel and in the area that you will put it on the boxblade. Then you can easily remove it when needed and simply bolt it on for use. Like my gauge wheels on my grading blade. :thumbsup:
actually I was just going to bolt it directly to the box blade..
J
   / Box scraper add on #6
Like this RT. :thumbsup: But paint to match. :thumbsup:
yeah BUT that extends the end of the fulcrum point farther back from the box and even 2 inches could be bad...
I think bolting it directly to the box blade would be good enough....
J
   / Box scraper add on #8
what about this?
   / Box scraper add on #10
I don't want to weld anything to it...
if I can help it...
I have a cheap box and that metal just did not take well to welding..
J
what if you just drill two holes and bolt it on? and maybe for added strength, cut two triangles and weld them under that lip for better strength.
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
3in Poly Pipe (A49461)
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
