Moving a cargo container
   / Moving a cargo container #11
I have a 40 foot shipping container two years ago when I moved into my home I ordered one and when the driver tried to unload it it slipped half way off the side of the truck. I thought for sure it was going to roll over my neighbors new fence and onto his new lawn. luckally it only slipped off his truck half way. I had the driver leave since he could not unload the shipping container. A fiew months later when I had rented a couple of large tracors and leveled out the bottom of my lot I had another container delivered. This time it was pretty uneventfull. The driver was able to deliver it where I wanted it.! Now of course the container is full of stuff and I an thinking of moving it a fiew hundred feet back on my lot. I want to build a garage where my container is presently located. Good luck moving your container I am also enjoying hearing the advice that you are getting on how to move your container. We don't live too far away from each other. I am 30 miles form Temecula CA. David
   / Moving a cargo container #12
country:
Excellent idea. I'm gonna havta position one and had planned to "log roll" in place. Your idea sounds lots better.
JEH
Country's idea sounds good to me too, but don't have extra wheels laying around. (neighbors... keep your wheelbarrows locked up).
I'm afraid I'll be like David and fill it up with stuff before I get a chance to move it off the driveway. After all, I did get it to store stuff in and it ain't doing me much good right now.
I'm thinking about jacking it up and laying some pipes underneath it to break friction with the ground (pipes won't need to roll), then give it another try with the pickup. If I can get it sitting on 6 or 8 square inches of metal surface instead of laying flat on the ground, it just might be pullable. If the pipes do roll a little... even better.
Thanks to everyone for all the great ideas... it was my first post after lurking here for a couple months and a good experience.
   / Moving a cargo container #14
Another cargo container story my new neighbor above me is having his lot graded for a home site. The contractor is operating a D8 dozer the lot has a lot of rocks and bolders some of them are pretty round. Well the container was stoared below the future home site. It looks like the Dozer was pushing a round bolder to the edge of the pad and the bolder did not stop it rolled down the hill and crashed into the shipping container the bolder was about 3 1/2 to 4 feet round. now the neighbors 40 foot container had a big dent about 5 foot form the corner of the container. So my quick advice don't store your container below any site you plan to grade if you have a bunch of large rocks. David
   / Moving a cargo container #15
Guys... I have two containers that are sitting on dirt. I'd like to get them up on some concrete blocks, or maybe treated 6x6s. Several of you in the thread above mention jacking the container up. Exactly what kind of jack are you suggesting to use to do this? My containers are 40 footers. Tare weight on each is 8,800 lbs. I've thought about digging a hole a couple feet in from the corner and putting my rolling car jack under there and seeing what happens, but I think the jack will simply fail. Then I have a ruined jack, and the container is still in the dirt.
What kind of jack do I need, and what method do I use? Really appreciate the advice. Thanks, Steve
   / Moving a cargo container #16
Stroll,
You are definitely going to need hydraulic jacks (4 ton) working together and a good platform under each to disperse the weight.
I would jack at one end and then move to the other. Also, you need to be careful about movement as you raise. I would definitely look at blocking it as you lift it just in case a jack slips.
Your profile, doesn't have a location, but one thing you should be concerned about if you raise the container up on 6 x 6s, is that you have now created a great habitat for snakes, mice, rats and other creatures of country living.
We have a container my wife uses for a hay barn. It sits one a pad of road base and I still have problems with the wildlife moving in. I am considering taking up the wood floor and filling the void with more road base to eliminate the habitat. I just need her to use the hay.
-ustmd
   / Moving a cargo container #17
Find a local house mover. It will not cost much to have them lift it and set it on cribbing or blocks for you. Or they could build a whoel foundation or whatever.
   / Moving a cargo container #18
I agree with ustmd that you only need two jacks and something stiff under them, like doubled 24" x 24" 3/4" plywood.
I don't think you need two 4-ton jacks. Lifting one end of an 8800 lb load only requires 4400 lbs force. Two hydraulic jacks with 3000 lb capacity each would be enough, but I would want 4000 lb to be on the safe side. (One jack at each corner on one end of the container.) This is only a 2-ton jack, available in most auto parts stores.
Lift a little, crib a little, and keep repeating.
I think treated 6 x 6 is the way to go. Single lengths that fit entirely under the container from side to side.
   / Moving a cargo container #19
Here's a video for you, at about 1:30 or so you get a look at their home-brewed adjustable jacking setup.
Also, check out the submitter's other clips with the home-made diesel garden tractor too.
YouTube - Kenya 2010
   / Moving a cargo container #20
I moved from the ground on to a trailer a 40 and then a 20 with 2 hi lift farm jacks the lift part fits in the hole on the end of the container the other end is onthe ground so it is stable. They were both jacked up high enough to get the trailes started the I used pipes between the trailer and the container and come a longs to pull the container on to the trailer. I un hooked the trailer so the toung would go up and align with the bottom of the container. The trailer was an 80 ft MH that I cut the front 40 ft off and used the I beams inside the back I beams all narrowed to 8ft wide the toung is now on the rear the axels are 2/3 back to the new rear/old front It worked out just right for halling the container 250 miles loaded with a lot of stuff. The 20 ft was the same but i used a 25ft Construction trailer. The trailers were given to me just to get them off the land. I dont plan on moving them again. I left them on the trailers blocked them up too high for critters to use as a home.Sorry it,s so long and not correct english but maby you can get the idea.
2012 Cadillac CTS Sedan (A55758)
2012 Cadillac CTS...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 Honda Accord (A55758)
2018 Honda Accord...
Giyi Log splitter (A53316)
Giyi Log splitter...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A55787)
2025 GIYI GY-BK56M...
MMS MS380R (A53316)
MMS MS380R (A53316)
