lights out- any guesses?
/ lights out- any guesses? #1
boughtaJD
mid Michigan
JD 2320
I was out boxblading a pasture on my 2320 at dusk yesterday and it started to get a little dark so i turned the lights on (headlights+ 3 dealer installed worklights) when i went over some uneven ground and had a mild bump cause all lights to go dark. I didn't have time to poke around to determine the problem last night & will look after work. Any ideas? There's been no problem so far with 250 hours on the machine. Thanks in advance for your thoughts.
/ lights out- any guesses? #3
First check the fuse to the lights. If it blew you likely have a short somewhere due to bare wire touching ground. Look over the wiring and connectors real good.
Fuse was blown & I did track down a bare wire on one of the work lights where the insulation must have worn through.
213088 (A64276)
213088 (A64276)
HOBAR 4 5212 BAND SAW (A64281)
HOBAR 4 5212 BAND...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
Military Transfer Cases (A64119)
Military Transfer...
Portable Air Compressor w/Honda Motor (A64119)
Portable Air...
UNUSED WOLVERINE HYD SICKLE BAR MOWER (A64281)
UNUSED WOLVERINE...
