stump for a chinese finish mower
/ stump for a chinese finish mower #1
robert421960
Rockholds Ky
2014 Kubota L3301
i bought this mower when i got my tractor and prolly only have 20 hrs on it
the gears sheared off while using it
any idea where i could get a stump cheap?
/ stump for a chinese finish mower #2
:confused:What is a "stump"?:confused2:
The only stumps I know of are uprooted by backhoes & excavators, and pushed over by bulldozers.
/ stump for a chinese finish mower #3
On the tractor? or on the mower? "Stump" as in tractor PTO output shaft? "Stump" as in mower transmission input or output shaft? Or "stump" as in mower spindle? Or is there another "stump" I've missed?
//greg//
/ stump for a chinese finish mower #5
//greg//
"Stump" jumper?
Steve
boy oh bot i started one now lol
stump as in rearend
stump like a truck rearend
stump guys geez things are sure different worded around the world i guess
im talking about the gearbox i guess sorry about the confusion and i hope everyone enjoyed a laugh:thumbsup:
/ stump for a chinese finish mower #7
It's called a "The Pumpkin "........................where I come from
/ stump for a chinese finish mower #8
I guess. Just out of curiosity, in what part of the world are you located? Your forum profile is basically empty.
Anyway, your question is still far from clear. Is it the mower transmission that you think needs to be replaced? I ask, because on a finish mower usually a belt breaks before any potential damage is fed back as far as the mower transmission. Perhaps if you described what was going on when whatever happened to make you believe you need a new "stump"
//greg//
/ stump for a chinese finish mower #9
I was wondering if it might be a shear bolt??? going into the gear box / stump :D
/ stump for a chinese finish mower #10
what brand of mower do you need a gear box for?
i bought it when i bought my tractor from the same local dealer
he said it is a chinese mower and he also sells tillers and box blades
they all seem to be junk in my opinion
there is no marking on the mower telling what brand it is
but when it quit working a few years back i just set it aside
this summer i tore into it to see what was wrong
i could turn the pto shaft and could hear grinding
i pulled the covers and
belts still look new
i turned pto shaft and belts didnt move
long story short i took the cover aff (pumpkin :D)
and see the ring and pinion gear are stripped
pinion is worse
so i figured i could buy a pumpkin maybe cheaper
i didnt know for sure
and before you assume things the pumpkin was filled corectly with oil
/ stump for a chinese finish mower #14
I would like to see a picture of this stump or pumpkin. I think it might help in identifying the part.
im gonna try to get some pics of the mower soon
J J i used to live in jacksonville fl
/ stump for a chinese finish mower #18
Since he stated "ring and pinion" (which is a hypoid gear set), that suggests a right angle (90°) drive, and would need to know the ratio, if other than 1:0-1. Also the mounting method. Surplus Center has a lot of those available.
/ stump for a chinese finish mower #19
If it is a finish mower, he is probably using the high PTO rpm setting, Some of the gearbox, have a gear ratio from 1 : 1 to 1 : 3, The blades on a finish mower have to spin faster than a bush hog.
/ stump for a chinese finish mower #20
that better greg????
Much better, thanks. Sounds like you simply need a 40hp implement gearbox (transmission). If you want to match the existing mounting bolt holes on the mower housing, that narrows down the field. But if you're willing to drill new holes, all you have to match up is the input and output shaft diameters. See GEARBOX 40 HP, SPLINED INPUT SHAFT - Agri Supply
And JJ makes a good point. If/when you get this mower fixed again, make sure you use it with the PTO select lever in the 540 position. If you use 720 or 1000, it won't be long before the thing self-destructs again.
//greg//
