PTO adapter help
/ PTO adapter help #1
green duck
Member
I have a heavy duty 6 foot bush hog on a cat-1 40 hp tractor. I want to use my bush hog on a cat-2 100+ hp tractor. I will be able to make a way to hook the cat-1 implement to the cat-2 tractor.
My question is, since the pto shaft on the bigger tractor is bigger, can I use some sort of a pto adapter? Also would this mess up my bush hog hooking it to a tractor with more rpms or would I just run the bigger tractor at a lower rpm to match the smaller tractor?
Any help would be appreciated since I have not done this kind of thing before,
Thanks
/ PTO adapter help #2
Do you have a higher rpm PTO on the cat II tractor? Higher than the standard 540?
/ PTO adapter help #4
Sounds like he is trying to hook up to a 1000 rpm shaft?? I would not do that, however, I would put the 540 shaft back in the tractor. Ken Sweet
/ PTO adapter help
I don't know.
The JD is a bigger tractor and the pto shaft is bigger than the one on my massey ferguson. I have seen these pto adapters around that you slide over the bigger shaft and it converts it to the smaller size. Allowing me to hook the smaller bush hog to the larger tractor.
Will this work? Something like this:
image.php
/ PTO adapter help #6
I don't know.
image.php
If that is in fact the adapter that will work, it looks like you have a really old bush hog with a smaller PTO shaft connect. It is probably a 1-3/8" to 1-1/8" adapter. This should be OK. Notice how both ends are 6 spline.
What is critical is the PTO speed. Look at the PTO shaft on the bigger tractor. If it has 6 splines, you should be OK at 540 RPM. If it has 20 or 21 splines, it is a 1000 RPM PTO and SHOULD NEVER be connected to a 540 RPM implement -- which your bush hog is.
/ PTO adapter help
Thanks. That's what I didn't know. The bush hog is prolly 15 year old bush hog brand. Don't know the model.
Thanks again
/ PTO adapter help #8
Thanks again
Just check the inside diameter of the brush hog. It should be standard 1 3/8 inch ID with 6 splines. If it is 1 1/4 6 spline, you will need to change the back to standard. Ken Sweet
/ PTO adapter help
I know it is 6 spline. Not sure on the size as I'm not there to measure right now. The bush hog hooks up fine to my Massey Ferguson 1540 if that helps.
Thanks
/ PTO adapter help #10
Man, I thought this stuff was more standard. The more searching I do the more confused I get!
/ PTO adapter help #11
What model JD tractor? The JD tractor may have a 540 and 1000 RPM PTO shaft that can be switched out.
/ PTO adapter help #12
15ys old??.. it should be 1 3/8...
soundguy
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2011 Ford Expedition SUV (A61574)
2011 Ford...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
Year: 2016 Make: Dodge Model: Charger Vehicle Type: Passenger Car Mileage: 59,224 Plate: Body Type: (A61574)
Year: 2016 Make...
