SQ480 shear pin didn't shear?
   / SQ480 shear pin didn't shear? #21
I get extra shear bolts and nuts. I find a spot in the framework to drill holes to keep the extra shear bolts in. Then I have a stock of 3-4 with the brush hog no matter where I go.
   / SQ480 shear pin didn't shear? #22
To leave the bolts loose will lower the torque needed to shear! Another way to lower the shear torque needed is to cut a groove into them!
Thanks for the tip on leaving it loose. I don't think notching will be necessary. I believe going from the #5 to #2 will make quite a difference already.
2021 Exmark Lazer Z 60in Zero Turn Mower (A49461)
2021 Exmark Lazer...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A51039)
John Deere 700...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
2008 CATERPILLAR D6K LGP PIPE LAYER (A50854)
2008 CATERPILLAR...
7046 (A50322)
7046 (A50322)
