RETIRED
/ RETIRED #1
R J WEPPNER
I wish to cut rubber conveyor belt.What is the best lub to use?
John WEPPNER AUSTRALIA
/ RETIRED #2
It depends what you are cutting it with. The best lube for rubber in many cases is soapy water. Sometimes lube can work against you. If you are using a saw the lube will cause the saw to get pinched. We make conveyors were I work. Several hundred miles of conveyor every year. We cut all the conveyor belt with utility knives with no lube. These are thin belts. 3/16" or less in thickness.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
SWITCH HITCH HYDRAULIC HAMMER ATTACHMENT (A60736)
SWITCH HITCH...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
YARD MULE (INOPERABLE) (A60736)
YARD MULE...
2020 Volvo L60H Articulated Wheel Loader (A61567)
2020 Volvo L60H...
