3-Point Hitch Please - a measurement on Class III Boomers
   / Please - a measurement on Class III Boomers #1
DocHeb
Michigan
New Holland TC40D Supersteer
I am not at my tractor and I need a measurement for a Class III TC34/40/45.
What is the height (approximately to the center of the hole) of the lower arms of the three point when they at their lowest position?
   / Please - a measurement on Class III Boomers #2
Chris, do you mean at the hitch balls? I'm away from my tractor right now too, but I'm sure the hitch ball will lower to around 6" off the ground. I do have TnT and that probably puts me a bit lower than some.
Yes, at the center hole of the lower arm hitch balls
   / Please - a measurement on Class III Boomers #4
Chris
Measured to the center of the 3pt lift arm ball hole on the non adjusting side (left) on a flat concrete floor 7".
I have a 2003 TC45DA with loaded R-4 17.5L-24
Jack
Thanks, I have R-4s also. That was about my recollection, and I will design a little lee-way in. Thanks
Forklift Safety Basket Attachment (A56857)
Forklift Safety...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
402 (A52706)
402 (A52706)
