Implement questions
   / Implement questions #1
Covfam
Member
Merrilan Wisconsin
I still havent decided quite yet on the compact tractor brand to go with yet :)
But i do have some questions about the implements. are the implements pushed by manufacturers any good?
for example are Bobcat implements, kubota (lands pride) John deere (frontier) Cub cadets implements ETC. are these implements as good as long time implement names like Woods, or Bush hog?
Basicly i was wondering if i ended up getting the dealer brand implements am i getting a decent implement or am i getting an overpriced cheap option.
Also do these manufacturers support their brand implements with warranty/& work?
Thanks again for answering my newb questions :)
   / Implement questions #2
Tractor branded implements and others you mention are usually good quality at a very high price. You can shop around and get comparable quality for considerable less money spent. Warranty on the products would be about the same. Ken Sweet
   / Implement questions #3
My only experience is buying a "John Deere" snowblower....a 64" Frontier.
It looks to be very well built (IMO) and the cost, through a JD dealer, was waaay reasonable.... $2100.00 or $100 less than a Martin Meteor.
I would say it is wise to shop for quality AND price. Educate yourself so that when you are shopping you know what you are looking at.
That said, TBN is a library of tractors and implements.
   / Implement questions #4
There are only so many manufactures. I think land pride is a Woods implement, not sure though. ANd i know that there is not a Frontier plant making bushogs, BB's, hay cutters etc. They are made at some other company painted green and decaled up.
   / Implement questions #5
i would say each implement needs to be selected individually, as quality and design can vary. However if you stick to a name brand (such as Woods, Bush Hog, etc.) you should be o.k. More important is matching the horsepower of your tractor to the horsepower rating of the implement. If you buy a light duty implement and use it with a high HP heavy tractor, you will regret it regardless of brand. Most companies make the same implement in several levels of durability, of course at an increased price. I like to buy implements at least to match my horsepower rating, if not more. Most implements sold at places like Tractor Supply seem to be light duty versions so beware if you buy a more powerful tractor. Buy the heaviest duty implement you can afford and you sill not regret it. Sometimes you will be limited by what your dealer stocks however.
   / Implement questions #6
Shop around beforehand so you know what is a competitive price for a quality implement. I think if you buy as a package, say an FEL and bushog, with your tractor, you will probably be able to get a price on the implements competitive with the major implement manufacturers. If not, check other dealers/makes or purchase from the implement manufacturers.
ok thanks,
i just wanted to make sure if i ordered any correct size/hp implement from my tractor dealer that i wasnt getting junk :) i know that as with everything i could find cheaper or better elsewhere but i wanted to make sure if i went with say john deere that at the very least i could get a decent implement from john deere. or if i got a kubota the lands pride implement was good :)
You guys have been great help with all my newbie questions, it seems the more i read /learn about tractors the more questions i get :p
   / Implement questions #8
ok thanks,
Just because the new equipment is at a John Deere dealership, does not necessarily mean it is quality equipment. We have 2 local JD stores that I have confirmed have JD colored green implements that are a box store Brand and low ball priced. If you don't buy John Deere fall back to the Frontier line, not the one that starts with the Letter A. Ken Sweet
   / Implement questions #9
ok thanks,
You won,t get junk fron a dealer maybe not the best price,like others said compare and shop around.You may do very well at your dealer if you can bundle a package:)Dave
Thanks , I have monochromatic vision (means i can only see black &white and shades of grey)
So i dont buy tractor/implements based on color but the actual brand/item & Price. but thanks for the tip ill make sure that any implement i get isnt a generic implement.:)
   / Implement questions #11
I would also suggest that you take your dealer suggestions with a "grain of salt", especially if you buy a bigger tractor and your dealer is like mine. When I bought my 70 horse Kubota, he sold me a package with a harrow and Woods Rotary cutter, basically what he had in stock. From what I have seen, most dealers stock entry level or light duty implements and don't stock the heavier duty stuff, as they sell fewer and cost more. Light duty is fine if you have a smaller tractor, and even the Tractor Supply brands are ok for smaller tractors. But the bigger the tractor and the harder you use it, the more care you need to take to select better, stouter implements. I trashed my standard duty Woods cutter after a few seasons of use (and yes, I was abusing it) and have since bought a heavier duty Woods that I like better. The John Deere stuff I have seen stocked at my local dealer seems fairly light duty, at least for my needs.
When I buy an implement now, I first see what brands local dealers carry and what they stock. I then look at the manufacturer's web site and look at the levels they make in that particular implement, and try to select one compatible with my tractors power and weight. If the cost jump is just too excessive, I have compromised and bought a lesser level, and accept the fact that it may not hold up as well. Some of it also depends on how much you use it. I use my rotary cutter a lot, and use it at its upper limit, so I want the heaviest duty one I can afford. Same for a disc, as a light weight disc is fairly worthless. However I bought a standard duty box blade, and it has held up pretty well. I would rather wait until I can afford the right implement rather than save money and buy something I will be unhappy with or worse, break.
My advise is to pick out what size tractor you need, then what implements you will use most, then ask on this thread which ones specifically people like, rather than the ones your dealer wants to sell you.
   / Implement questions #12
Sorry to be obtuse Ken, but I haven't shopped implements at a Deere dealership and do not know what brands are commonly found at them. I have figured out that Frontier is their house brand, but what brands start with the letter A?
Do I own one of them? ;)
   / Implement questions #13
   / Implement questions #15
Someone already mentioned the importance of mating the implement to the tractor size. I think this is often over looked in these general implement discussions. In my opinion some under buy and some over buy. If your needs are met with a smaller 20 something horse power tractor then lighter duty implements will most likely met your needs fine. If you are looking at 40+ hp then I would answer the question a different way.
MarkV
   / Implement questions #16
first thing you need to consider is how big a tractor you need.you don't want to fall short,or go overboard.the second thing you need to consider is dealer support,look at the reputations of your local dealers,ask around.does'nt hurt.as far as implements.you will pay more for a quality piece,the cheap stuff is just that,don't expect a long service life with it.for a mower,i like the bush hog brand,been around forever and they have a good rep for quality stuff.the frontier line is also good stuff.just depends on what kind of job you are looking to do.i would say kubota is about JD's only competitor out there right now,but they all are getting better.the TYN tractors seem to be decent,and they have an excellent warranty,and i hear their dealer support is great.i prefer the green machines,been running them forever and they have always given me good service without alot of problems.nothing is bullet proof,they are machines,they will wear,some just wear out faster.i guess it boils down to your budget,and what you want to do with it.if you are in question,just ask on the forum,lots of good advise to be had on here.good luck with your decision.
   / Implement questions #17
Thanks for clearing that up for me Ken. I noticed the Howse copyrights on the Agrevere web page.
When I bought my equipment, most of the dealers in my area were promoting packages with the Howse boxblade and mowers. Not just the Kubota guys, but the Mahindra, Ford, Bobcat and IH guys too.
When I shared the advertised package deals with my Kubota dealer during my price negotiation he kinda chortled and indicated the Mohawk cutter was a much better product and that the Howse boxblade in the packages was also kinda flimsy compared to the line he carried (Armstrong AG). I did not know he might have meant the entire product line, I only thought he was comparing the specific models. :eek:
I have a lighter tractor and my usage demands are fairly light compared to commercial users, so while standard duty equipment will probably be durable enough for me in most cases it is nice to know when to look more closely at a product to ensure it compares well to other standard duty lines.
   / Implement questions #18
Landpride headquarters is in Salina KS. Woods headquarters is Oregon IL. Unless there has been a take over/buy out, they are 2 distinct companies. I have used and liked Landpride and heard good things about Woods.
I believe dealers will push what is on their lot. I know I would in there position. Sometimes it is up to the buyer to do research and not be so dependent on "expert" dealer advice.
I expect buying implements is a bit like buying oats. If you are satisfied with oats that has already been through the horse, it should be cheaper.
thanks for the advice, like i posted in other posts im looking at the smaller compacts, under 30-35hp,
Im not going to be doing heavy duty rock/tree lifting/plowing, ill be snow blowing my drive, box grading my drive, fence post digging, rough cut mowing along the fenceline, and then twice a year cutting & baling 2-3 acres of hay with a mini round hay baler, possibly pulling a cart with several said 30 lb bales.
Other than the snow blower im not sure if i need heavy duty. Ive narrowed my tractors down to a 2,000 series john deere or a B series Kubota it will be one with at least a 20hp PTO so that i can get some of the bigger subcompact/compact tractor implements, ive been on the mahindra,cub cadet,new holland and theieor smaller tractors just dont fit me as well, the john deere and the kubota feel more organized/roomy to me. both dealers have been pretty good with me, (i had trouble with a previous JD dealer trying to sell me 30 grand in implements and tried to convince me that i needed a 55hp tractor to mow my fenceline)
Honestly where im having trouble is wich one i like better as for right now both tractors feel good to me, over the next month they will both be bringing out to me a demo unit and tach me how to safely use the tractor... some of the other dealers like the (nh dealer) didnt have time to help educate me he just wanted me to buy a boomer, because apparantly me looking at NH's economy tractors just wouldnt work <shrugs>.
Since its my first tractor i have a hard time guaging between what i want and what i need :)
   / Implement questions #20
When buying implements look at the construction to include material thickness and quality of welds. Paint color on an implement makes little difference to me as long as it functions and holds up under normal use.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2020 DRAGON ESP...
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
Bobcat 863 Compact Wheel Loader Skid Steer (A59228)
Bobcat 863 Compact...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2020 CATERPILLAR 320 GC EXCAVATOR (A60429)
2020 CATERPILLAR...
