Implement questions
   / Implement questions #1
Covfam
Merrilan Wisconsin
I still havent decided quite yet on the compact tractor brand to go with yet :)
But i do have some questions about the implements. are the implements pushed by manufacturers any good?
for example are Bobcat implements, kubota (lands pride) John deere (frontier) Cub cadets implements ETC. are these implements as good as long time implement names like Woods, or Bush hog?
Basicly i was wondering if i ended up getting the dealer brand implements am i getting a decent implement or am i getting an overpriced cheap option.
Also do these manufacturers support their brand implements with warranty/& work?
Thanks again for answering my newb questions :)
   / Implement questions #2
Tractor branded implements and others you mention are usually good quality at a very high price. You can shop around and get comparable quality for considerable less money spent. Warranty on the products would be about the same. Ken Sweet
   / Implement questions #3
My only experience is buying a "John Deere" snowblower....a 64" Frontier.
It looks to be very well built (IMO) and the cost, through a JD dealer, was waaay reasonable.... $2100.00 or $100 less than a Martin Meteor.
I would say it is wise to shop for quality AND price. Educate yourself so that when you are shopping you know what you are looking at.
That said, TBN is a library of tractors and implements.
   / Implement questions #4
There are only so many manufactures. I think land pride is a Woods implement, not sure though. ANd i know that there is not a Frontier plant making bushogs, BB's, hay cutters etc. They are made at some other company painted green and decaled up.
   / Implement questions #5
i would say each implement needs to be selected individually, as quality and design can vary. However if you stick to a name brand (such as Woods, Bush Hog, etc.) you should be o.k. More important is matching the horsepower of your tractor to the horsepower rating of the implement. If you buy a light duty implement and use it with a high HP heavy tractor, you will regret it regardless of brand. Most companies make the same implement in several levels of durability, of course at an increased price. I like to buy implements at least to match my horsepower rating, if not more. Most implements sold at places like Tractor Supply seem to be light duty versions so beware if you buy a more powerful tractor. Buy the heaviest duty implement you can afford and you sill not regret it. Sometimes you will be limited by what your dealer stocks however.
   / Implement questions #6
Shop around beforehand so you know what is a competitive price for a quality implement. I think if you buy as a package, say an FEL and bushog, with your tractor, you will probably be able to get a price on the implements competitive with the major implement manufacturers. If not, check other dealers/makes or purchase from the implement manufacturers.
ok thanks,
i just wanted to make sure if i ordered any correct size/hp implement from my tractor dealer that i wasnt getting junk :) i know that as with everything i could find cheaper or better elsewhere but i wanted to make sure if i went with say john deere that at the very least i could get a decent implement from john deere. or if i got a kubota the lands pride implement was good :)
You guys have been great help with all my newbie questions, it seems the more i read /learn about tractors the more questions i get :p
   / Implement questions #8
ok thanks,
Just because the new equipment is at a John Deere dealership, does not necessarily mean it is quality equipment. We have 2 local JD stores that I have confirmed have JD colored green implements that are a box store Brand and low ball priced. If you don't buy John Deere fall back to the Frontier line, not the one that starts with the Letter A. Ken Sweet
   / Implement questions #9
ok thanks,
You won,t get junk fron a dealer maybe not the best price,like others said compare and shop around.You may do very well at your dealer if you can bundle a package:)Dave
Thanks , I have monochromatic vision (means i can only see black &white and shades of grey)
So i dont buy tractor/implements based on color but the actual brand/item & Price. but thanks for the tip ill make sure that any implement i get isnt a generic implement.:)
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
CATERPILLAR 420F2 IT BACKHOE (A60429)
CATERPILLAR 420F2...
