MF GC2300/2310 Filters OEM Part Numbers
   / MF GC2300/2310 Filters OEM Part Numbers #1
ray66v
Super Member
Ohio
GC2310,
Thought I would repost these for those who may not have them:
GC2300/2310 OEM part #'s:
Engine Oil Filter:3609410M1
Engine Air Filter:3757472M1
Trans Oil Filter:4265229M91
Fuel Filter:3608255M1
Service Manual:4283003M1
Parts Manual:651743M92
Other numbers available upon request.
   / MF GC2300/2310 Filters OEM Part Numbers #2
I will post the engine oil filter part # Monday--that part # subs
Thanks for taking the time to post this great info for poeple
   / MF GC2300/2310 Filters OEM Part Numbers #3
Engine Oil Filter:72201898 "new part number" fits GC2300---1533
Fuel Filter:3608255M1 Fits GC2300---1533
Service Manual:4283003M1 All GC2300---GC2310TLB
Parts Manual:651743M92---prior S/N JNA25200
Parts Manual:651794m91---Eff. S/N JNA25201 "With Tack"
Engine Service Manual: 1449395m3
Thank you for the updates.
   / MF GC2300/2310 Filters OEM Part Numbers #5
I know this is an old thread but I had used the search function a few weeks ago to find these part numbers which I ordered.
However, today I received an email from Jacks Small Engines that the part numbers for the manuals below are no longer available. Anyone have a new part # or can tell me where I can get these manuals?
1449395m3 and 651743m92
I don't necessarily NEED these manuals at the moment, I just wanted to get them while I could in case I need them 10 years down the road. :thumbsup:
Thanks!
   / MF GC2300/2310 Filters OEM Part Numbers #6
Could you post the #'s for the same parts that are on the GC2610, along with the manuals? Thanks in advance.
   / MF GC2300/2310 Filters OEM Part Numbers #7
F.Y.I. :D
Massey Ferguson GC2400 / GC2410 / GC2600 / GC2610 Compact Tractors:
MF PART DESCRIPTION MF PART #
Workshop Service Manual # 4283093M1 (March, 2008)
Iseki Three-Cylinder Diesel Engine Manual # 4283035M1 (2006)
Parts Catalog Publication # 651875M2 (March, 2008)
Engine Block Heater Kit # 4269250M91
Engine Oil Filter # 72201898
Transmission/Hydraulic Filter # 4265229M1
Air Cleaner Element # 3757472M91
Fuel Filter Element # 3608255M1
Seat Switch # 6253456M92
Thermostat # 3704299M1
O-Ring Thermostat Housing # 3702478M1
Lower Radiator Hose # 4264879M1
Upper Radiator Hose # 4264878M1
V-Cog Belt # 6252466M1
___________________________________________________
Also, F.Y.I. :thumbsup:
The products listed below are what I decided to use in my 2009 GC2410TLB for the Daily Service, for the 50 Hour Service, 100 Hour Service, for the 200 Hour Service, and for the Yearly Service (all items were purchased at my local Auto Parts Store):
Valvoline SynPower Synthetic Grease (NLGI #2 GC-LB lithium complex EP)
Amsoil Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30 (ATH)
Amsoil Synthetic Gear Lube SAE 80W-90
Amsoil Synthetic Heavy Duty Diesel Oil 10W-30/SAE 30 (ACD)
Napa Chain & Cable Lube Spray
Napa Dry Graphite Film Lubricant Spray
Napa 50/50 Antifreeze/Coolant
As for fuel, I use a local station, CONOCO; in the summer, I use the #2 Off Road Dyed Diesel, and in the winter, I use the #1 winter blend Off Road Dyed and add some Power Service Diesel Fuel Supplement (in the white bottle).
Note: There are other cheaper and expensive fluids available, but for the $$$$$ that I have invested in my tractor, I believe that I am feeding my tractor with good synthetic fluids :D :D :D. KC
P.S. I hope this information can help others make their own decision as to which fluids they are going to feed their tractor, ;). Also, I have performed the 50 Hour Service on my tractor just last month.
MF Red, I think those are excellent choices, except for the antifreeze.
I would suggest you use an antifreeze that is made just for diesel service. It will come with all the additives, rather than adding them, which I assume your doing.
However if your changing it every year, like the manual says, I don't know if it will matter a lot.
I have decided not to replace mine every year. Mostly, because I don't put a lot of hours on my tractor.
   / MF GC2300/2310 Filters OEM Part Numbers #9
F.Y.I. :D
Thanks for all the great info. Are those the most recent publications or are there newer ones?
   / MF GC2300/2310 Filters OEM Part Numbers #10
Hey ray66v, thanks for the info, I did not know there was a different anti-freeze for diesels. I will check at my local auto parts store, since I will not be changing the fluid out until November, :thumbsup:. KC
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
