Toyboy
I've got a couple bottles of ATF and no use for them. Somewhere on here I read that mixing it w/fuel was a good thing. If that it a true story, what would the ratio be per 5 gal in my BX. I'm want to use it up.
unless I misse dit.. I did not see atf in that study.
and with mmo being stoddards solvent mostly IIRC.. I don't doubt it did poorly..
soundguy
No, you don't want to put ATF in diesel fuel. Why? ATF typically contains friction modifiers which are beneficial to an automatic transmission but detrimental to a fuel system. Friction is the killer of a diesel fuel system, that's why so many problems occurred when ULSD was introduced, they couldn't handle the lack of lubricity and increased friction created from ULSD. Adding ATF to the fuel would just increase this problem. Run a good additive such as Power Service, Stanadyne,...you pick.
It doesn't matter in a tractor, but another reason why you shouldn't run ATF in a diesel vehicle is because ATF is red, it'll tint the fuel the same color as off road. Need I say more?
Save them to start the fire to burn all those old tires. You might not want to filter the acid since it might destroy the cheesecloth.![]()
so.. get the older atf that you can still get.. IE.. 70's era technology.. like type f..
me? I like some type f and mineral spirits or kerosene and a lil naptha in a hand squirt can as a penetrant oil.
soundguy
Never put "Type F" in anything but a ford transmission!!!
Type F has " grit" in it. Will wipe out a diesel pump.
I've got a couple of gallons of used brake fluid (DOT 4 mostly), some old power steering fluid, some used carb clearner solvents, and some used battery acid, but I don't have any used ATF.
Which of these chemicals, if I filter them through a cheesecloth to remove the big chunks, are good to recycle through my RV's Mercedes diesel engine, or should I just dump them all into my tractors fuel tanks?
