deere5105
- Joined
- May 6, 2009
- Messages
- 1,096
- Location
- South Mississippi
- Tractor
- 2008 John Deere 5303 MFWD, 2004 John Deere 5205
Noticed yesterday while running my JD MX6 cutter in thick grass that it quit cutting. Raised it up and it picked back up and would cut fine. Next pass when I get to the thick grass it slows or stops again. First thought was the slip clutch was slipping. Tightened up slip clutch today, sharpened blades and tried it again. I had the same results again. The tractor is not loading up when it begins to slip. We also have a 6' Howse cutter with a shear pin set up. I hooked to it and again had the same results. Tractor is a 2004 with 370 hrs. I have spent probably 60% to 70% of these hours with the cutter running. My thoughts are the PTO clutch on the tractor is slipping. I have no issues changing gears or the clutch slipping on the transmission. Any thoughts or ideas as to what is happening?
