Backhoe 5310 backhoe
/ 5310 backhoe #1
picanoor
angleton texas
Massey Ferguson 254 John Deere 990-4700-5310-new holland tn65-kubota l3300-l4200Ferguson to 30,1951-to30,1954, ford 2n 1947, ford 2n 1943 jd 5200, jd 301a, alllis chalmers 45c, John Deere 5200
I just bough a 5310 JD with front end loader.
I wan to use my backhoe behind this one, what is the best (most cost effective way) to install power beyond on the 5310?
/ 5310 backhoe #2
/ 5310 backhoe
Thanks,
i went trhough this site but am not sure if i need to add a power beyond valve, and which one.
when I added the power beyond to my 990 i bought a kit from john deere which included some lines and Scv conecters, no valve.
installation was quick and simple. is this option also available for a 5310?
/ 5310 backhoe #4
Thanks,
Yes, you need Power Beyond. It's not a "valve", just a set of lines that provide continuous flow whenever the tractor is running. If you look in JDParts, look under "P" for power beyond, there are several listed depending on which SCV configuration you have. The one below is for 0 or 1 rear SCV's.
There is a quick tutorial linked in my signature if you need help with JDParts.
/ 5310 backhoe
thanks for the in info,
finally got the tracor shipped to the house and did some checking.
i have 2 sets of remote scv on the back connected to my front end loader, the valve block has 3 extra connections capped off on right side (wheel side).
if i look up the power beyond coupler kit ( with 2 or 3 scv) the kit has hoses for 3 couplers:
one to male quick connect.
one from bottom of block to hose to male quick connect
and then one that is going from bottom of block to a female quick connect. these are looped together.
the last one from top back of block to male quick connect where do i use that one for? eaxtra return leak oil line? see attachment.
/ 5310 backhoe #6
The "extra" line should be a direct return to the sump/tank, bypassing the 3PH since you don't want it active while the backhoe is mounted.
/ 5310 backhoe
ok thanks,
i do have an overflow /pressure relief valve and line coming from my backhoe block which right now blows the oil to the ground, so i can connect it to this one.
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
204158 (A57193)
204158 (A57193)
2025 IRGC40 Electric Tricycle Cart (A60352)
2025 IRGC40...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2015 Komatsu PC360LCLC-10 Hydraulic Excavator (A60352)
2015 Komatsu...
