Chisel Plow
   / Chisel Plow
Price is more like $150. $50 is about a scrap price for it. Heavy penetration is fine if it springs over but from the pics this thing looks pretty ridgid.
   / Chisel Plow #12
clemsonfor, can I make the assumption you are a tater fan????????
   / Chisel Plow
What????
Does this have something to do with football?
   / Chisel Plow #14
It is one of those 'in between' contraptions. down south it might be called a chisel plow, but up here in the north it is just a heavy field cultivator.
Broken spring, price them - if you can still get them? You might be surprised what it costs.
The sweeps - the replaceable shovels on it - all look to be worn out on the one side, and I only saw one that has a good side left. Those will run $10 or so per shank with new bolts to replace, & you do need to replace those worn out ones.
Looks like it sat a while in the grove. Obviously the owner didn't think it was work a lot....
I'd be closer to the $50 than the $150 in my offer. Seems it need a lot. I bought something like it for $300; but it had good almost new shovels, and all springs were good.
You'll be over $300 and a lot of time getting the old bolts off....
It'll rip up grass in sandy soil. It would be a several pass, long task to do so in heavy clay soil like I have. That's the big varriable -what your soils are like.
I'm not impressed by the thing for the price, as you can tell. :)
--->Paul
   / Chisel Plow
OK i checked. We all can see one point has another side, but i prolly will buy 5 to have an extra.
*Points 5/8 thick $3.49/piece x 5 = ~$17.50
*Bolts, i figure i can buy all i need at the store for $10 ( i have boght a few bolts at my local carquest so i have an idea of price)
*Spring (hard since i dont have it and not seeing the whole supply at TSC) but at agrisupply there is some for $9 and some for $30? unknown?
So even figuring $30 for a spring and $20 for new points and 10 for bolts thats $60. Glad were looking at it this way, thanks for pointing out the obvious which i saw but did not price yet.
   / Chisel Plow #16
What????
Yep!! IF you ever frequent Tiger or Gamecock Illustrated forums, you will learn that Tiger fans are called taters, and Gamecock fans are called coots. It's all in fun, but was just wondering if you were big tiger fan is all.
   / Chisel Plow #17
If you are wanting to plow up sod a mowboard plow would do much better or mow it short and kill it off with Round up then chisle plow. Then disc it to death. You will fight clumps of sod until they break up or rot.
Dan
   / Chisel Plow #19
Ken what HP does it take to pull the chisel plow in your photo and if you don't mind send me a PM on price. Thanks Deere 755
Probably around 40-50 with 2 wheel drive tractor could handle 5 in most conditions. I have a 4 shank chisel (shown below) also the same $695 price as the 5 shown earlier. Of course the 4 would take even less and both have removable shanks to match tractor size and field conditions. Ken Sweet
   / Chisel Plow
This is what i read on an older post, that it takes 15hp per shank, that would mean this 5 shank would take 75hp. This plow im looking at is from the middle to late 50's . How many 75 hp tractors existed back then and who had them? In the 50's my great granddad was proably still using a mule back then.
This dosent seem to make sense to me, i can pull my box blade with the 4 rippers lowered as deep as the dirt will allow them to go (BB tilted foward to get them deeper) and my yanmar 24hp will pull it all day long, i even busted the far tine through my asphault, be it thin asphault but still, as i was ripping the edge of the drive for my wife.
The way i see those rippers on your true "chisel plow" the only difference is the length. I agree, i will not burry them 10" and pull them but on a similar field to mine my bb without weight would only go 4-6''s the ground was so hard.
2008 KENWORTH T300 CHEMICAL TRANSPORT TRUCK (A50854)
2008 KENWORTH T300...
2008 FORTITUDE MANUFACTURING 40X96 FLATBED (A50854)
2008 FORTITUDE...
RoGator 844 sprayer (A50490)
RoGator 844...
2018 FORD F-150 XL (A50854)
2018 FORD F-150 XL...
71058 (A49346)
71058 (A49346)
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
