Chisel Plow
   / Chisel Plow #31
Ted's sod does not look like the heavy fescue/orchard grass/clover sod I have in my pasture fields. With that type sod that Ted has to work with, You should do well. Ken Sweet
   / Chisel Plow #32
How much weight on the disk?:D
Wasn't sure if this was towards me or not. I actually don't have any weight on my disk. Once I figured out how to set it up properly, I found it wasn't needed. A lot less stress on everything that way. That being said, not all disks are created and some do need weight. Some need a lot of weight.
   / Chisel Plow #33
I have a 7 shank field cultivator similar to the one in the first post, mine is in good shape with almost new points. I pull it mostly in my garden with a 33HP Ford tractor, with few problems having enough power. I pull it over plowed land if there is no trash to clog me up, 8 to 10 inches deep. And I remove the center shank to cultivate my garden rows. Any dirt that was worked last year will be no problem this year. Like I said, a 2810 II tractor, 33 HP, and very few problems.
I worked on a dairy farm a few years ago doing field work. I pulled a 7 shank chisel plow similar to the third post, using a 5000 Ford with an aftermarket turbo and, somebody said , the fuel pump was turned up to really increase the HP. The chisel was pulled through corn stubble where we cut corn for silage. The chisel was about all the 5000 could handle.
I guess my point is the chisel takes a lot more tractor than the cultivator.
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
