Need Help Getting FEL Control Cables
/ Need Help Getting FEL Control Cables #1
3RRL
Super Member
Foothills of the Giant Sequoia's, California
55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Hi guys,
Thought someone out there could help provide a link to a place where I can get replacement FEL control cables. I have a Koyker 195 loader with a Dinoil valve. It has a Cofle joystick. I called Koyker today and they no longer carry the cable I need, which is their part number 669296 control cable. They do have the 20" longer ones and want $100 for one cable. But the ones I have now are already a bit too long, so I'd really like to stick to those.
If you know where I can get an aftermarket that will fit, please help.
Thanks,
Rob-
/ Need Help Getting FEL Control Cables #3
Google "Custom Motorcyle Cables" and phrases similar to that...one of my buddies here likes to restore OLD Snowmobiles...which ALL parts are NLA and has been able to custom order all his cables from places like this:
Motion Pro - Custom Cables
/ Need Help Getting FEL Control Cables #4
/ Need Help Getting FEL Control Cables #5
Are you looking for a cable or hose? I looked at the manual (quickly) and didn't see any cables, just a pretty standard loader.
/ Need Help Getting FEL Control Cables #6
Thanks for all the links guys.
I've checked them out but have not come across the exact cable end that fits the Cofle joystick. I'll keep looking and perhaps get one of those links to make one up for me. I've also considered making the plastic end (which is what broke), out of silicon bronze or aluminum. That plastic end (either Delrin or Nylon) is injection-molded over the brass cable end. I'll give that some more thought when I have time. I could make several spares since I've broken 2 of those plastic ends in the last 5 years.
Right, the cable and not the hoses.
The Cofle joystick and cables are not listed in the Koyker manual since there are many ways the Dinoil valve can be actuated. Mine is done via control cables which connect to the valve.
/ Need Help Getting FEL Control Cables #9
Our pals at SurplusCntr had a bunch of industrial push/pull cables for sale.
I bought one and used it for a custom remote valve set up. I just went and
checked....they only have a few sizes now, and not so cheap.
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
iDrive TDS-2010H...
2016 Mercedes-Benz 300SLK Coupe (A61574)
2016 Mercedes-Benz...
2020 Case TV370B (A64126)
2020 Case TV370B...
