Cylinder rebuild help needed?
/ Cylinder rebuild help needed? #1
IslandManMitch
Pineywoods of Florida
John Deere 4600
This is the cylinder that has been used for a top link. It was used cylinder and retrofitted years ago and has worked fine except it has always leaked a little. Getting worse and it is to the point it needs rebuilding. The rod end cover had two 1/4" bolt holding it on which I removed. I put the two bolts back in the cylinder to screw it out. Turns freely but does not screw out or in? How does it come out? Where can I get a rebuild kit? I have looked with no luck? This is the first cylinder I have tried to rebuild and I'm already lost? Thanks for any help, Mitch
/ Cylinder rebuild help needed? #2
Sir
I had a older cylinder that was being held in place by a special fitting at the rod end that was part of the 1/2 npt hydraulic fitting. I would take take the rod end fitting off and look in there.
Craig Clayton
/ Cylinder rebuild help needed? #3
Does the gland push in? I am thinking there is a internal snap ring that keeps the gland from coming out.
You probably won't be able to get a "kit", but once it's apart the a local hydraulics shop should be able to match them up. If you chose to buy online you will need to be able to accurately measure the seals, A great place to buy from is www.herculesus.com
/ Cylinder rebuild help needed? #4
Kenny nailed it. Spray some good penetrating oil around where the gland meets the barrel, wait about a half hour, and tap the gland down the barrel until you see the internal snap ring. Remove the snap ring and use the rod like a slide hammer to knock the gland out. Oh, one more thing, get that brass fitting out of your system.
Andy
Thanks everyone for the information. I will try your suggestions tomorrow. The brass fittings came with the set up with no problems after 5 years. I am guessing the hydraulic pressure is to high for them and I have been lucky? I will take your advice and change them out regardless of the reason why. Do they need to be "hydraulic" fittings? I guess I can get them when I get new seals from the hydraulic shop? thanks again, Mitch
/ Cylinder rebuild help needed? #6
The brass is not rated for the pressure, better that the cast iron plumbing fitting from Home Cheapot-but still not correct. You need steel fittings.
/ Cylinder rebuild help needed? #7
So are they brass fittings or zinc plated steel? Magnet would tell for sure. Definitely change them out if they are brass.
Kim
/ Cylinder rebuild help needed? #8
For all those that don't know, not all brass fittings are alike. There are different grades of brass. Some say never use brass fittings, but there are some brass fittings that will withstand up to 3500 psi to a 5000 psi test burst pressure. This data is from Gates. Look on page 212. Excellent source of hose specs and fittings.
http://www.royalbrassandhose.com/catpdf/catalog.pdf
So how do you know if the brass fittings you have is rated for high pressure. You probably will not know, unless you purchased it from a hyd supply. The fittings from Home Depot, probably are for low pressure.
Used Kenny and Andys directions and it came apart easy. I will take it to the hydraulic shop next week to see if they can match up the seals.
The fitting are for sure brass. They may be the high pressure ones like J.J.'s talking about but I'll change them out while I have everything apart just to be sure. Thanks, Mitch
/ Cylinder rebuild help needed? #10
Great! Glad to help. Keep us posted on the repair;)
I took the cylinder parts to Coastal Equipment & Hydraulics in Cantonment, Florida today. Wally was the guy that helped me and did a first class job of getting everything I needed and took the time to show me how the seals fit. Total bill $47.48 including new steel fittings. Everything went back together without a hitch. I hooked up the 6' bush hog and left it hanging for over two hours with no leak down. Thanks again for the help. Congratulations to you KennyD on being the member of the month. It is easy to see why you were chosen. Mitch
/ Cylinder rebuild help needed? #12
Holy crap batman! News to me:eek::eek::eek::eek: Where did you read this?
Glad you got the parts OK...Wally sounds like a good guy:D
You really didn't know? Ah shucks, grin, yeah right. Go to Tractorbynet Home. It is right there front page.
/ Cylinder rebuild help needed? #14
No, I didn't! My shortcut to TBN brings me directly to the forums...WOW:D
/ Cylinder rebuild help needed? #15
Kennyd, if you did congrats. You do deserve it. I can not find it!!!!!! Did search and found nothing. May be by the 30th we will all know.
/ Cylinder rebuild help needed? #18
Thanks guys, I do see it now:thumbsup:
Kenny, enjoy the balloons, confetti, champagne, caviar and notoriety. You deserve it and I am pleased to be the one that broke the news to you.
I used the top link all day and it worked fine. I will never be reluctant to tear into a cylinder again. Mitch
/ Cylinder rebuild help needed? #20
Thanks Mitch:thumbsup:
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
TRIP HOPPER JR CUBE / CAKE FEEDER (A64278)
TRIP HOPPER JR...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
PALLET OF TRACTOR WEIGHTS (A64278)
PALLET OF TRACTOR...
