Spot Sprayer for Round Up
   / Spot Sprayer for Round Up #1
KU Gator
Topeka, KS
Kubota B2920
I live on 3 acres with a 400+ ft drive, a 200 ft long rock filled ditch and an old fence line down one side of the yard that require weed and grass spraying. I have a 3 pt PTO sprayer I use for weeds in the yard but did not want to put Round up type spray in it both because the punp is not a Round Up ready pump and did not want to risk dripping as I drove around. So had been using a back pack sprayer which while an improvement over the round pump sprayer was clearly my most dreaded chore.
Yesterday I went to a new Tractor Supply near where I work and bought a 15 gallon spot sprayer with the 12 volt demand pump on it for $79. I was planning to put it on the carry-all on the back of the tractor, but then noticed it would fit neatly in the bucket. Then instead of hooking it to the tractor battery, I put a trolling motor battery in the bucket beside it. It ended up working great. It has a 20' hose, so if there was a lot to do in an area I could pull up and get off and spray or along the fence line could just spray while driving. Having it in the bucket also had the benefit of a secondary containment incase there was any leaking which there wasn't.
Tractor Supply also had their Big N Tuff brand generic Round up at a lowered price of $49 for 2.5 gallon. It is 41% of the active ingrediant, so goes a long way.
   / Spot Sprayer for Round Up #2
In a perfect world there would be as many TSC stores as Walmarts. :) Best hand sprayer I ever had is from TSC and it was $8 :D
   / Spot Sprayer for Round Up #3
Both the sprayer and Roundup were great prices. I paid $110 I think for my 15-gal sprayer, and $69 for the glyphosate 2.5 gallons.
   / Spot Sprayer for Round Up #4
I feel bad for y'all. Here in Central KY I'm paying +/- $39 for 2.5 gallons of 41% glyphosate (Buccaneer Plus, to be specific) at a local ag chemical supplier.
   / Spot Sprayer for Round Up #5
Name and address of this supplier please.
   / Spot Sprayer for Round Up #8
Great use of the tractor and it's bucket. I can think of a better use of the trolling motor battery.
   / Spot Sprayer for Round Up #9
some great info I had the same thought but was concerned about dripping also glad to hear that was not a problem. Instead of my BX was thinking of putting one in back of my RTV 900 and spray from seat.
   / Spot Sprayer for Round Up #10
Does the generic RoundUp work as well? I just bought a new 2 1/2 gal. of RoundUp Max. I think it was 51% but I don't have the jug handy to look at. I was looking at the generic stuff because it is so much cheaper but it seems like for me if I go cheap on something I am disappointed. Brian
My experience has been they both kill the weeds. Round Up seems to act quicker and you usually seed results in a couple of days. The other sometimes takes a week. I first noticed in a Lowes when looking at quart size that the Round Up they had was something like 18% so it took a lot more to equal the same concentration as I believe it was Total Kill that was 41%. The stuff I bought at Tractor Supply said it had a surfactant in it which based on the way it foamed, I suspect it was basicly dish washing soap. After the 1st tank mix, I started putting in most of the water before adding the weed killer to avoid so much waiting on the foam to go down. Oh well, used the time lubing the FEL.
   / Spot Sprayer for Round Up #12
What I'm missing here? I don't know what this pump is. ( the punp is not a Round Up ready pump ) How do I know if mine is?
   / Spot Sprayer for Round Up #13
I have been using the generic round-up this year. Get it from our county noxious weed department for about $22.00 for 2-1/2 gallon. It seems to me that things comeback faster, but that is probably just due to the rainfall we have had this year. I mix it exactly as I have mixed the "real" stuff and haven't noticed any difference in the killing ability. I use a sprayer mounted on a 4 wheeler.
   / Spot Sprayer for Round Up #14
We use a sprayer in the bed of our Rhino for spraying as it is a lot quicker and smoother to get around our farms.
LeeJohn - On the box, it says it is "Round Up Ready". I wasn't highly concerned about that as I wasn't comfortable with putting it in my bigger sprayer as it tends to drip a little and didn't really want to risk the roller pump which was a little more than this whole rig and was tired of walking around with that 3 gallon sprayer on my back. I figgured I was willing to risk $80 and just make sure I clean it well after each use. I was mainly just passing on what ended up being a pretty simple solution to spraying the product.
The problem for me about buying herbicides through the county is it requires taking time off from work as they are open the same hours I work and since I actually work in a different county than I live, I can't easily do it on my lunch hour.
   / Spot Sprayer for Round Up #16
I have never seen that before. I'll look at that when I go get one, the old one is just about had it. Thanks
   / Spot Sprayer for Round Up #17
I saw the 15 Gal sprayer at TSC today for $99, think it had a 12' hose. Was yours on sale for $79? What does it mean by "roundup ready"? I need a sprayer like this to keep a gravel parking area weed free.
   / Spot Sprayer for Round Up #18
I do just that with my RTV 900. Well, my wife enjoys driving the RTV, so she drives and I spray.
I'm in the process of trying to rid my farm of privet (a truly abominable invasive species). I have a 15 gallon sprayer with a 1 gpm flow rate that does a decent job, but I plan to upgrade to a 25 gallon sprayer with a 2gpm flow rate.
The battery location on the RTV makes it easy to attach the alligator clips of the sprayer's electrical wiring, but I was thinking about rigging up a connection to the 12 volt outlet on the RTV's dash.
Here's a photo of my (make that our) RTV with the sprayer.
Steve
I don't really know if it was on sale or not. This is a new store in Lawrence KS. It had only been open about a week. So it may have been an Manager Special type thing. When I first saw it in the store, I did not buy it if for no other reason than I was on the motorcycle that day, but I went back and looked it up on line and it was listed there for $99 also. Actually after buying it on a Friday and using it on Saturday morning, I got a coupon in the mail from TS for 10% off if the total purchase was over $100. I went back to the store on Tuesday, and the Manager said no problem, put the $150 I had spent on Friday back on my card and re-rung it with the discount, so the net was $71 for the sprayer.
The manager at the store told me when I bought it that as he understood they put some different seals in the pump that would hold up better to the Roundup which is very caustic. The PTO roller pump I bought is not supposed to be Roundup ready. I still flushed the tank and ran clean water through it 3 or 4 times before putting it up. I believe this one has a 20' hose with it.
   / Spot Sprayer for Round Up #20
thanks, I did see it for $79 on amazon. my last TSC coupon had expired, so I didn't get the sprayer. I have a 2 gal hand pump sprayer dedicated to roundup, I have separate sprayers for everything, but thought the electric one would be nice because I need to do a large area.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
500BBL WHEELED...
More info coming soon! (A56858)
More info coming...
2019 CATERPILLAR 336 EXCAVATOR (A60429)
2019 CATERPILLAR...
