Rotary Cutter Size Matters
/ Size Matters #1
DanielJ
Member
Tyler, TX
John Deere 5625
Need some advice on rotary cutters. I am looking at buying a 80'ish HP tractor and a bush hog. I am told that the cutter should "cover the tires". That means 77 - 80 inches and a 7' or 8' cutter. I've had some advice that the 84" mowers protrude so far behind the tractor that they can be difficult to maneuver in tight places.
On the other hand the double headed 8 footers don't protrude so far to the rear but are more expensive and really seem wide.
Some sage advice would be appreciated.
/ Size Matters #2
I have a Kubota M8540 tractor. I think my R4s sit about 7 1/2' wide but I use a 6' cutter. I was going to get a 7' cutter but decided against it because of the size of that 7'er... it sticks WAY out the back!
I considered an 8' (dual spindle) cutter but decided it was too big to fit in my garage. If I had the space, I would have bought the 8'er.
My 6'er isn't wide enough to "cover my tracks" but that hasn't been an issue for me. Now that I have used my cutter several times, I really like the size. I can maneuver it in places that a biger cutter would prove difficult.
/ Size Matters #4
We sell dual spindle cutters and single spindle type of cutters. Only use dual spindle, if you need that extra cutting width. They have 3 gearboxes on them and also connections between the outboard and center drivebox to maintain. The single spindle 7 or 8 ft is a lot less expensive to maintain and cost less. Ken Sweet
/ Size Matters #5
I use two cutters on my 80 HP tractor, a Woods 121 10' 3-point hitch and a Woods DS1260 10'6" pull type. The 121 is really pretty maneuverable. The pull type is a really good cutter, but not very maneuverable.
We got the pull type to cut the heavier stuff the 121 wouldn't handle.
/ Size Matters
Thanks to RJ, CharlieS, Ken and RRR for the help. It's nice to get advice from people who have been there and done that. Thanks again.
/ Size Matters #7
Good luck. Have you given any consideration to a flail?
/ Size Matters #8
Your welcome and let us know what you do and maybe post some pictures. Ken Sweet
/ Size Matters #9
My thought also. You can get an 8ft flail that will cover your tracks without the long overhang on the 3pt hitch.
72in Blue Diamond Grapple Bucket (A65579)
72in Blue Diamond...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
Kioti LK3054 Tractor (A66285)
Kioti LK3054...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
